Old 03-09-2007, 07:05 AM   #2101
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Hi all
I just got a 007 and am trying to install the 2 belts for it. I have the diffs and the belts in place and when I rotate the spur gear, If feels like the larger belt is catching on something because there is resistance at a point. Has anyone had this issue and know some ways to solve it?
Also, how important is it to clean and re-oil the bearings before you run the car for the first time? I think those are blue rubber sealed and they are hard to get open. I have no problem with the diffs and spur gear being free and stuff so I was wondering if it was a big deal.
Thanks for the help
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline   Reply With Quote
Old 03-09-2007, 07:09 AM   #2102
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Originally Posted by Ridge_Racer
Hi all
Thanks for the help
Check the screws on the spur gear, they may be hitting the upper deck. This is a common issue with the 007. You may need to add some additional countersink to the holes in the spur.
As for the bearings, it is best to oil them before the first time you use them.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 03-09-2007, 07:25 AM   #2103
Patriiick's Avatar
check also that the screws holding the spur gear are not too long, damaging slightly the pulley in process, thus creating a hard point... happened to me on my T2 build initially.
Patriiick is offline   Reply With Quote
Old 03-09-2007, 07:28 AM   #2104
I don't think I have the upper deck installed yet. I have the diffs and spur in place using the Alu upper clamps. I also have the rear upperdeck installed (just found out) but I don't think that is touching anything. I will check when i get off work.
Thanks again
Old 03-09-2007, 07:41 AM   #2105
hi, check your pulleys F/R. i had a small tiny piece of flashing ihad to trim off cause it was touching the graphite lip of the spot where they are recessed.
MManson is offline   Reply With Quote
Old 03-09-2007, 08:38 AM   #2106
Hi again.
I'm getting a little ahead of myself with this one but I was wondering where to start for gearing. I was gearing my TC3 at 7.5 FDR. With the XRay's light chassis I was thinking of gearing up if using a stock or C027 motor.
Old 03-09-2007, 10:00 AM   #2107
Default bearing question
i'm at work, so i cant measure them:
What are the size of the bearings that are used in the rear ALUMINUM uprights that Xray sells? Are they the SAME size as the bearings used in the team tamale ones?
Old 03-09-2007, 10:02 AM   #2108
theisgroup's Avatar
no, the xray uprights have a burshing that hold the bearing so they are smaller. the team tamale ones use the stock bearing
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-09-2007, 10:10 AM   #2109
5x9x3, stock size is 5x10x4
Retired from RC....
Old 03-09-2007, 10:20 AM   #2110
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
What's the best fan system to use these days? Are fan necessary? I've noticed some criticism on the MuchMore fans.
AWhich size spur will give the best range of gearing? Can the car resist small debris well enough to use 64 pitch on asphalt?
Also what arrangements of shims, spacers, hubs etc.. are a good starting point for setup?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 03-09-2007, 10:47 AM   #2111
thanks guys!
Old 03-09-2007, 11:06 AM   #2112
ShaunMac's Avatar
Did you get a new 007 Dane? You going to race asphalt in Trenton?
Check out www.teamxray.com Click on >>>SET-UP SHEETS
-there's a bunch of good info on the XRAY site.
See you soon!
ShaunMac is offline   Reply With Quote
Old 03-09-2007, 11:39 AM   #2113
Dane's Avatar
See you soon!
Asphalt in Trenton? Have details?
Nah - bought a T2R. Have you received the cyclone yet?
Thanks man
Old 03-09-2007, 11:41 AM   #2114
Ok, I checked the car over to see where the belt was hanging up at. It looks like the larger forward belt will, at a point, start rubbing on the side of my front one way. That is, the belt would move to the side, start rubbing and then move back toward center. Is their some alignment problem somewhere? I did notice that, on the spur gear, one of those composite hubs that hold the bearings was installed backwards. I fixed that and the rubbing continues. I will check into your other suggestions when I get home today.
any clues (thanks for the help so far)
Old 03-09-2007, 11:44 AM   #2115
the belt wandering on the F/R pulleys is normal.
Well, let me re-phrase that. my car does it. But I an not normal.
so, it cound be un-normal if it does it?
lol
