Team Losi JRXS Type-R
Yeah its good to see everyone posting setups and stuff, not many people seem to like the Losi, maybe its just the name, i know before i had one we would laugh at the car, but since i have had mine a lot of people had taken notice of it, and i do agree the car has a LARGE sweet spot, with my 416 i was always chasing car setup, the only thing i'm looking for with the typr R is a bit more mid corner grip, it just a bit pushy mid corner.
The car is able to hold it's own against T3's BD5's and the like.
Rhys
Rhys
What we were looking at is moving the steering servo to the side, moving the battery and motor forward, and moving the layshaft back behind the motor (if required). The idea is to have 50/50 on all corners with battery and motor 1st, then servo and ESC in the center of the wheelbase. This should in theory allow much faster rotation in the middle of the corner as the weight is not spread across the length of the chassis.
The original change in the layout to the type R was for better balance with BRUSHED motors and NIMH batteries. These days we run BRUSHLESS and LIPO which means the motors are now heavier and the batteries lighter. When you think about where these are in the car you will understand how the balance has changed.
I understand what your saying with balance but in so doing, with you changes your changing it from its unique stand point and in turn will make it in some way like every other car thats out there. Electronics one side batteries on the other or close to that. I for one like the uniqueness of where it is now and think it should not change one bit. Its liked for its uniqueness and the FACT that it does not behave like any normal TC. Just my opinion and 2 cents.
We are in two minds in regards to the placement of the layshaft. The theory is by moving it between the motor and rear axle, we have a nice long stretchy front belt, which means a bit more front traction. Otherwise we have to have a slightly shorter front belt than we currently have and slightly longer rear. It doubt this will cause any noticeable increase in rear traction and would surely have less front traction compared to the other option.
We are very close to prototyping. Carbon will be here in a few days for the alpha chassis. I have learned from the past not to make any promises on timelines, so no idea when the chassis will be available if they prove successful. Luckily for me, I have more top level test drivers locally than recently, so proving its speed will be easier.
I agree that my conclusion of saying it would be like any other tc was drastic, but it still does not change the fact that you will be changing the uniqueness of the car. If you move the servo and the battery, would you not in turn have to mill a new chasis plate, top plate as well as make new rear axle bulkheads and possibly fronts, seeing as how you will be changing the lengths of belts in the process?
Look I am not knocking your ingenuity to make changes to this car, every driver out there has to put lead on their car to make the balancing even but not everyone I think would want to revamp the car to make that balancing change if you have to put so much more cost to get that done. I believe LFairtrace said he did not balance his car and he was wining with it. If i misqouted you Larry I apologize.
Again this is just my opinion. Everyone says this car is so good out the box just seems like alot of things looking to get changed that don't makes that much sense to be changed. More power if you make this work I just dont think its necessary to change something that is not broke.
Hey guys just a question
will the springs from a losi xxxs fit on the jrxs shocks??
Cheers
Cheers
Not sure which camp I fall in, but I do like the option to add things here and there if the mood strikes me. Part of the reason i chose the Type-R was to have something different.
I am for making changes to the car in the sense of tweaking things. I liked the layshaft option even though I have no invested in one yet or the spool option. This just sounds like a big revamp to me. I am all for minor tweaks. Like I said thats just my two cents to this topic. I am sure people who want to see big changes will like the moving of the motor, servo, and having to get different dimension belts and whatever else will need to be purchased. I wish you guys the best of luck in that change.
Its not so much ingenuity, but plain physics. The most dense parts of the car is the motor followed by the lead ballast. This weight is placed at either end of the car creating a high moment of inertia resisting initial rotation and then resisting stopping of rotation at corner exit. I have discussed this with the former losi prototype engineer and he fully agrees.
Also remember that even though this car was quite lipo friendly, it was designed and tested at a time when brushed motors(lighter than brushless) and NiMH(much heavier tha lipo) were still used. When using the heavy brushless and light lipo's this car become rear biased. Yes Larry won without balancing but that is not to say that this already great car can't be improved(Larry would probably not agree though).
I have great support from some of the best drivers in OZ and there is no better time to get this happening as Losi appear to have stopped stocking top decks!
I await the final product...
Just spoke with LOSI... Parts are now being phased out officially. Car is DEAD. Bummer!
Someone Take Torys shoelaces
