Losi Truggy
#1382
You can use "Team Losi Adjustable Front Hinge Pin Brace W/Inserts: 8B/8T - LOSA1754" for adjusting Front Roll Center.
With stock kick-up you can get 5 positions for Front Roll Center:
1) 0-insert in front, 0-insert in rear (stock)
2) 0.5-insert front top, 0.5-insert rear top
3) 1-insert front top, 1-insert rear top
4) 0.5-insert front bottom, 0.5-insert rear bottom
5) 1-insert front bottom, 1-insert rear bottom
For other kick-up values, for example stock+1°, you can get 3 positions
1) 0.5-insert front top, 0.5-insert rear bottom
2) 1-insert front top, 0-insert in rear
3) 0-insert in front, 1-insert rear bottom
and so on...
and so on...
#1384
X2....i rebuilt all mine thinkin the same thing....but Nope....inserts look like brand new.. Two thumbs up
#1385
and so on...
and so on...
#1386
That table related to changing height of Front Roll Center.
Stock Kick-up and Caster are quite fine, you don't need to change that. Run 0° inserts in both front and rear front braces.
Total Kick Up 14° = Chassis Kick Up 14° + Suspension Mount Kick Up 0°
Total Caster Angle 20° = Caster Angle 6° + Chassis Kick Up 14° + Suspension Mount Kick Up 0°
KICK-UP (FRONT)
Front kick-up is the angle of the front lower suspension arm when viewed from the side of the car. With kick-up the front of the arm is higher than the rear of the arm. Kick-up may be built into the design of the chassis plate (bend upwards at the front) or it may be accomplished by altering the angle of the front lower inner pivot pins.
Front kick-up is used to adjust the amount of weight transfer to the front when the car is off-throttle or under braking.
EFFECTS OF FRONT KICK-UP ADJUSTMENT
More kick-up
* More weight transfer to the front of the chassis off-throttle or under braking
* Chassis compresses or drops more off-throttle or under braking
* Handling is improved on bumpy tracks
* Decreased steering response
Less kick-up
* Less weight transfer to the front of the chassis off-throttle or under braking
* Chassis compresses or drops less off-throttle or under braking
* Handling is improved on smooth tracks
* Increased steering response
FRONT ROLL CENTER
Typically on off-road cars front roll center is adjusted using the front upper camber link inner mounting position on the front shock tower. Those same holes on the front shock tower may also be used to adjust camber rise.
EFFECTS OF FRONT ROLL CENTER ADJUSTMENT
Lower roll center
* Increases steering into corner
* Car is less responsive
Higher roll center
* Decreases steering into corner
* Car is more responsive
* Use in high-grip conditions
KICK-UP (FRONT)
More kick-up
Less kick-up
FRONT ROLL CENTER
Lower roll center
Higher roll center
#1387
Great post, thanks Vlad!
#1388
Allright, what does it take to get rid of the rear diff problems in the truggy, or can you? I was at the RC Pro State race, and the truck was really fast, but I could not seem to keep a rear diff in it. Track blue grooved, so there was tons of traction. In 3 heats, Main (Bumped), 2nd Main = 5 times on the track the truck came off with a rear diff problem 5 times. In my 1st main that I won and bumped, luckily it happened on the last lap of the race and I had lapped 2nd place. Not sure what to do, through the course of the 3 qualifiers I had already replaced the case, inserts, pinion, bearings, rear center cva....I like the truck, but that was ridiculous...
#1389
KICK-UP (FRONT)
More kick-up
Less kick-up
FRONT ROLL CENTER
Lower roll center
Higher roll center
KICK-UP (FRONT)
More kick-up
Less kick-up
FRONT ROLL CENTER
Lower roll center
Higher roll center
#1390
jsmax---Sorry to hear about the problems, but congrats on placing well. Mabybe your truck needs more attention with diff shimming. Like making sure it's tight to start with and then seat in. And using the HD diffs. I sure haven't had the troubles you seem to be having. I haven't been doing anything special with the diffs in my Losi's. I'm putting in the HD diffs this week hoping to never have a problem in the future. But I havent' had super powerful engines in my T yet. So my rear diff hasn't really been "punished," so to speak. LOL. I hope you get it solved though.
#1391
Car turns more, but it's take more time to get response from turning the steering wheel.
Same thing take place with overly thick shock oil. Slowed response.
#1392
I have not been running any shims in mine as the local guys told you did not have to with the Losi. I am not running a to powerful motor either, the Go 7 port runs out well but is very smooth on bottom. All I can say is that I have not had these problems in the past, but this is also the first time I ran on a track that blue grooved and had TONS of traction, maybe just to much for the truck. Maybe it needs the adjustable rear hinge pin plates so that I can go down to 2.5* toe when the traction is that high......
#1393
Hi guys!i have put the 8's shocks in my mbx5r and i need the 2 plastic little pieces that are inquding with the rear 8t arms.do anyone have an of these that don't need them?if not i most buy and the arms together and i dodntt need them..
Any help guys please?
#1395
i run OFNA diff oils....priced right and u get a decent amount.
