Tamiya TB Evolution V
#376
Orded mine Yesterday will be with me by WED hopfuly will keep you posted as to its speed handeling ect compaired to my MSX Great car ...............
#377
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Edd hurry up we being left behind here in the UK other racers will have the car first
#379
Yeah i want to get my Peak Li-Po init
#380
I´ve tested the Evo 5 a couple of trainings now and I can say that it´s as fast or even faster than my MSX. Great turn-in and allround steering yet the rear remains very stable. I contribute this to the new arms. The new steering setup has very little slop and the drivetrain is very free. One-way gear problems is a thing of the past I think.
I drive on a big euro-style track (18s) with low-med grip, seems to fit the car very well. The kit setup seems to be a good starting point also.
#381
Hopefully tomorrow i will recieve my Evo V and my new spare steering setup and arms for me to fit on my MSX. I will update everyone if and when it arrives.
#382
I tested the new steering on the 415msx
It works fine.
But even with the new arms and new steering system mounted on the 415, the evo 5 has more cornering speed and more steer turn in.
But still waiting for a spool to race the evo 5 in competition.
It works fine.
#383
Has anyone tried running without swaybars? Tried mine and was handling better without it. This was on stock setup running rubbers on smooth asphalt.
#384
arghh sway bar`s (rollbars in uk) pain in the arse
i don`t use then any where indoor,outdoor rubber
foams we don`t use , more then likley to use then
R/Bars will only work when properly setup which can take a age with fiddling
might put one on front but it has to be like a RSG beam girder, coz the piddly thin wire things do diddley squat
i run with out & i can run very fast with out them (just my thought`s0
#385
Some Evo V pictures are posted at the below link.
http://www.rctech.net/forum/showthread.php?t=119618
#386
Has anyone tried shimming the transmission any different to the instructions? I have put the shims on the oneway so that it is all the way out. It makes a cracking noise when I accelerate. I have changed it back to the instructions and now no noise. If anyone has any advice then please post on here. Thanks.
#387
Any tips on building this car as im going to start mine at the weekend ?
Do you guys remove the shielding from one side of the small hub/axle bearings to flush them or leave them in place ?
#389
The kit settings were just right with my car, though I did spend a lot of time playing around with the shimming of the rear input shaft, which on my car had too much fore-aft movement.
#390
