Silver Can Motor Tips/Tricks
#106
how are you zapping a can thats factory sealed? are you zapping the motor while its turning on a battery or take it apart and zap can only, but its kind of hard to put back together with out it looking like it was tampered with any help here??
i thought about this, i have my own zapper, has anyone tryed with motor turning low rpm?? so you dont magnitize the arm
#107
the arm doesnt magnetize therefore zap can complete.
#108
Originally Posted by James35
"Pretty tricky"? So are you saying it's possible to change the brush tension?
#109
Howzit All,
I would like your comments... I have a theory that a shaft chassis (i.e. Pro4 / TC4) is more appropriate for silver-can racing, as it is more capable of setting a smoother+efficient running drive-train. Also, what is better for the diff's ... diff/diff or one-way/diff or spool/diff?
Thanks guys!
Vance.
Thanks guys!
Vance.
#110
yes thats correct shafts are better for silver can racing. The diff can depend on what you find is the best for what track you race at. for one track a person i know uses a spool then for another track he uses a one-way this is all using a silver can
#111
Originally Posted by Vance
Howzit All,
Thanks guys!
Vance.
Thanks guys!
Vance.
#112
i currently run a Tamiya TB Evo IV and will be using that for 540 racing. the internal gear ratio is 2.294. the Spur is a 96T. the tyres are tamiya type B3 +/- 63mm. how would you guys recommend i gear this car?
#113
RR,
Goto www.gearchart.com. I recommend 49-51mm for a long high speed track and 44-48mm for a short twisty track. Have you tried the chamoise glove, soak in water, nitro freezed... yet?
Cheers,
Vance.
Cheers,
Vance.
#114
No Vance i haven't, i just started running 540 so i am a bit new to the class. i have been running super stock since last year. i will give it a try.
#118
thanks for the tip. I have experimented with a fair few liquids trying out on my comm by far the best was brasso but the problem was that the brasso would burn under high voltage racing conditions and stain the comm black rendering my 540's useless after a major race event. I highly suggest AGAINST using brasso, shellite works ok, but its a little too dangerous for my liking and i now refuse to use it.
What is the toilet cleaner - water ratio you use, i have a dyno so i can give you some dyno numbers when i get around to trying it out.
