Axiom Motors
#361
Axiom is now is the UK with our Distributor Smart Racing. If you are in the UK please support them:
http://www.smartracing.co.uk/
We have just sent them quite a huge inventory of stuff and more to come...
#362
Dave,
I was just about to buy a bushing reamer for my motors but I just read that EddieO doesn't ream bushings. What is your take (or anyone elses) on reaming bushings. I will post what he said. Thanks
#363
I agree with EddieO on not doing it and in my opinion its a waste of time.. We dont do it at all.. Your better off just polishing the shaft on the Arm.. A motor that has been broken in properly will have the bushings broken in from normal wear..
I dont suggest it at all. Infact your more than likely to do it wrong and have to replace your bushings which is gonna cost you more money and time.
#364
reaming
I've only had (1) motor that had the bushings reamed. Did not like it. I used a drill press and jig to make sure it was straight, but it made the hole too large. the arm "vibrated" under certain rpm's and I'm SURE that cause a backlash not allowing the motor to run as it should. I just polish the arm and that's it.
#365
Your wasting your time....don't ream the bushings...I don't do it....
Later EddieO
If yer going to do anything, just polish the arm.....and then lube really well...
We don't polish or ream the bushings anymore....
Why? Reaming isn't something thats EASY....in fact, your 99% more likely to do it incorrectly than to do it right....and even if you do it correctly, I still don't think it does anything worth a crap....
Polishing the bushings would be better in my mind......but it has the fatal flaw, that the bushings are very very pourous, so you can never get all the polishing compound residue out of the bushing....
A properly broke in motor will have the bushings broken in by normal wear.....just make sure they are fully seated in the holes before running the motor the first time.....
As for results.....not a single of the stock titles or tqs in the signature below had the bushings reamed or polished....so if we can do it at a national race against some of the best in the world, I am pretty sure you will be just fine at your local club race or two day event.
Later EddieO
This is what he had to say about the topic. Does anyone replace bushings?
Later EddieO
Later EddieO
#366
How and what are you using to polish the shaft.
#367
Company Representative
http://www.motortuningsecrets.com/tunestockmotor.html
Toothpaste works as does Mothers or any other chrome polish...
Be sure and CLEAN it VERY!!!VERY!!!VERY!!!! well after you polish it.
If you don't it will keep polishing the shaft and bushing as you run the motor...
Both will be junk then.
#370
Originally Posted by HenBeav
do you sell just motor tubes i saw them as an option to add to buying motors but didn't see any just individual tubes
I started adding that as an option and was playing with the idea as some dont like getting the extra pair of brushes.
I tried ordering 1000 motor tubes and the guy insisted on me getting a sample first - whatever. Anyways got the sample - wow its a tube - and they are on order. Oh and he sends me a pink one for a sample. Any takers
#371
Will you be selling Checkpoint motors
#372
i like using Brasso it seems to be the easiest and fastest IMO
it seems to wipe clean and havent had any problems with residue in my motors... Allso after just a few passes my bushings look like a mirror you could brush your hair in
good luck
good luck
#374
It will be a month or so until I need any motors but I will keep looking and hope you get some
#375
YES!!!!
