OCM KAOS DOMINATING
#1802
The arms look like they were boiled...Ive been told u can let them sit in WD-40 for a few days, Its a mechanical loobricant,It softens them.
Also with gearing u can use Buggy gears Crown/Pinion and go up to 48 teeth centre sper and run 12 tooth clutch bell....With a 28 u will get plenty bottom and top.
#1803
Outdrives will tell the tale, OCM is printed on them, mugens are silver.Fronts look like mugen. Look at the color difference between front and rear, that's not the stock motor mount either.
#1804
Well I was told the old arms were stiff and hard that is why they were easier to break, also in cold whether. If that was true.... I do not know. Now I heard the good arms are very flexible which the ones on this truggy are and the new arms I have in stock are flexible too so who knows. BTW Pooldoc the front diff outdrives on my truggy are grey and do not say OCM and the rear diff outdrives say OCM on them.
#1806
Yeah alot of things got messed up. The truck was supposed to be a roller, ever see a roller come with no radio tray and mounts, no radio box, no shocks and shock mounts? Also my 100 worth of parts did not show up in the shipment I paid for and my new evo kit I bought also is missing wheels and tires along with a used buggy I was supposed to get. Another guy ended up with the used buggy he did not expect and missing most of his parts he order too.
#1811
OCMACE94, where did you get a truggy from, just curious?
#1812
I'll have to try the WD-40 on a set of truggy arms. The first batch, that I boiled for 20 minutes, couldn't hold up to the abuse I put them through when breaking the truck in. They started to show stress cracks on the underside of the arms in addition to the one arm that I snapped.
If any updated arms come through, please post. If the Caster arms are a direct fit, I may try them.
#1813
#1814
[QUOTE=vnmsgt;4577802]Yeah alot of things got messed up.
that seems to be the theme here
#1815
Chris,
The arms I have are very stiff, no doubt about it. They were the arms that AB held the truggies up for. He did some testing on them off the truck and was able to snap quite a few of them. After boiling, they do get a little softer.
If the new arms feel soft to you, I definitely need to order some of those arms. I'll probably get 2 sets of OCM front and lower arms to try.
