View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#2626
After the beating mine took at the GORC Im thinking about getting a new body, all the traction rolls I got in the main killed it. So far the 68 camaro has worked the best for me, although I have a Cuda body sitting here unpainted. Ill probably just get the camaro again.
#2627
I fully understand the USVTA rules and because Novak helped to create the class so USVTA stands behind them.
We do this too because ORCA made a special brushless system for our Mini series.
I do see however 8 esc's that aren't novak in the rule set on the website but why aren't the hobbywing esc's listed on the PDF?
I run the Cirtix by the way.
Some people are anti manufactures and that's fine, but a motor isn't going to cause you car to burst in flames if geared right.
I had a Novak 10.5 way over geared in my SCT and all it did was stop. It was somewhere like 250F-300F......
I've never seen an on road esc flame! If plugged in backwards, (Operator error) it was just a puff of smoke.
I tried the javelin, but like the Boss 302 better. To bad the front of the Boss is so weak and flimsy.
Shoo Goo and some vinyl screen made it strong though.
#2628
#2631
I've got a question for those of you who run a Novak Ballistic 25.5 and a Novak GTB2 ESC. Has your VTA ever stalled after rolling to a stop? For some reason my VTA will not move after the car has come to a complete stop. If somebody gives it a push it will go just fine. I have already run Novak's Hall Sensor Test™ on my GTB2 and all the LEDs show that the timing sensor is working 100%. I also swapped out the sensor wire just to make sure it not a wire issue. But the car still does not move from a dead stop!
#2632
Make sure your 3 timing screws arent too tight. That happened to me when I first got into it. Just literally snug them, dont tighten them. Soon as I fixed that (thanks to Darkside) All was good.
#2634
There was nothing wrong with the Ballistic motor, it was the ESC that had a problem. So my guess is that you may have something wrong with the GTB2 ESC. It could be a bad sensor input or a bad motor drive circuit.
#2635
I checked the 3 timing screws and just made them snug. The car still does not move from a dead stop. This $uck$ bad!
#2636
Yes. I had the same thing happen to me at the USVTA Southern Nationals. I had a Ballistic 25.5 and a Speed Passion Cirtix Stock Club ESC. My VTA just would not start moving after coming to a complete stop. I replaced the Speed Passion ESC with a brand new Novak Edge ESC and the problem disappeared.
#2637
BTW, My comment "regardless of what RobK or anyone else thinks" was to simply say your opinion or anyone else's wont change my opinion of the rule. If you allow it at races you run then thats up to you.
If something is in the rule book and its too difficult to police then maybe it shouldn't be in the rule book, or maybe all that is needed is to define what is acceptable use of traction compound and whats not.
And no I'm not saying the rules need to be changed. Just clarified. Someone new should be able to read the rules and have no question as to what's allowed and what's not. I had my wife read that specific rule, she doesn't race, and her thought was the same as mine.
#2640
It's just my opinion. All I'm saying is that if I had to start troubleshooting a VTA motor/ESC combo, I would start looking at the ESC first. You already did the Novak Hall Sensor Test, so that rules out the timing sensor and sensor wire from being faulty. Using process of elimination, the next thing to check would be the ESC's drive output. Has your GTB2 been used to drive a modified motor? If so did the ESC overheat?
