#1157
#1158
This is my first time on this thread....
Can someone please tell me if I can use a new upgrade software on my Hobby King 100Amp esc/6.5 T motor with hand programmer. If so, could you please give me a link for the download.
thank-you....
thank-you....
#1159
CobraRacing, others as well
Coming from the 4300kx ezrun 9t motor, i could run the motor at 4.74 FDR for about 15mins w/o the motor getting too hot,,just barely warm. Now with my xerun 5.5 6000kv, It is only a tad faster from the 4300kv, and warms up alot quicker. The speed gain wasnt worth the temp gain.
If its true that these motors run cooler, that and the advantage of their size, could a version of these smaller motors with the cooling finns from the ezrun series in a sensored version to be used in sensored racing be worth an idea?
#1160
Hi Guys,
Need your clarification, im using 2 in 1 LCD program card for my Hobbywings ESC's, but when i tried to plug in my EZrun 60A V1.1, it only says Connecting to ESC what is causing this? any ideas?,.... also can the firmware be also be upgraded?like version2 or something or use the turbo function... or the new firmware is only for sensored BL?
Thanks in advance.
Thanks in advance.
#1161
#1162
Cobraracing,
PM sent
PM sent
#1163
Anyone run a Novak Ballistic 10.5t with 528 software?
Any idea on timing and gearing diffrences from Sp V3?
#1164
Does anyone actually have an opinion on which firmware is the best in area of safer to run?, I noticed the latest with the advanced features is listed as MOD, where as the previous are listed as STOCK, which I find confusing.
#1165
What were you running for the V3 SP?, I ask because I'm still figuring out what to try with mine.
Stock is for stock motors from 21.5T to 10T
#1166
Hence my confusion with 528 being shown as 528_MOD, full turbo with a mod motor?, that would melt my 60A on first use.
#1167
What you just said makes no sense, considering 528 is the latest firmware, people in here have been talking about using it with stock motors, and it's got all the same features as the previous firmwares labeled as 'stock'.
It's a little confusing until you realise that the numbers refer to the date of release, not the software version.
#1168
there are 2 versions of 528, 528_Stock for use with "Stock motors" 10.5 to 21.5 and 528_Mod for use with motors below 10 turns. 528_Mod has the exact same features as 528_Stock but the settings are very mild in comparison.
