#6721
I have the same problem with FDR 3.39 (66T spur, 37T Pinion), i can match top end speed with other guys but i have to brake so early to try and get round our hairpin that the other guys have left me :-(
#6722
#6723
Isn't drag brake a percentage of the full brake force? I thought I read that somewhere and I will do a test to confirm it.
I just loaded the new v3 stock software into my ESC and set the drag brake to my previous value. It was much more effective and I reduced my setting from 30% to 15%. I am running the 4 capacitors though.
#6724
211 vs 930 stock
Hi guys
Just a quick question. I have been running 211stock software and have just changed to 930 stock. What differences will I feel when running the same settings? Anything?
Cheers
Cheers
#6725
need a setup for xtremestock with speed passion 17.5 boosted ASAP!
indoor carpet, small to medium size track
#6728
try another battery with a higher discharge rating and also drop your punch level .by two so if your running 9 got to 7 .
#6731
#6733
#6734
Try to play with th-trim. Give there +1 or +2.
#6735
Tried the V3 no timing on the Just Stock last night. Couldn't tell if the brakes were stronger. My lap times are the same but the temp went down 20F. Really happy with the update. Good job.
