Hot Bodies Cyclone
hi guys , could any of you tell me the weight of you cyclone WCE , 5cell mod .
Because the minimum weight at my local track for running mod , 5cell is 1450 gramms and my car weighs 1507 gramm . and i would like to lower the weight down to around 1460 ,is this possible ,if yes could you tell me
Thank you
Thank you
Thank you
Thank you
Anyways the WCE chassis is the same as the Hara/Surikarn/Black chassis. But is only slightly diffrent than the new TC chassis. There is no advantage of 1 chassis to another.
Thank you
Thank you
Also no heat sink/fan on the motor.
Thank you
Thank you
yeah i live in the UK but i would like to achieve a lower weight without buying any more esc , motor , low profile servo . i might get a low profile servo but beetween the low profile and the normal servo theres no weight differente . i would like to get a lower weight without buying anything more . My electrinic are GTB , LRP bl 5.5 5cell micro receiver and normal servo . if its not possible , tell me but i would like to lower the wieght by triming , shaving anything possibl thanks
Anybody do any testing with the r9-r on the cyclone yet? I need a new body and was thinking of picking up this body or just going with the tried and true mazda6
thats what i was thinking but just wanted to make sure since the R9-R is a new on the market and so far i have heard nothing but good things about it
Last price drop on my cyclone, everything shipped for 300!
http://www.rctech.net/forum/r-c-item...s-charger.html
how could i increase steering under braking without decreasing on throtle steering too much . will more rear droop help by allowing more weight in front
if your rear spring is silver, you can decreasing front droop ,
can more on power turn .
More rear droop will help. You can also lay the front shocks down some which will make it softer in the front.
thanks guys i will try more rear droop and less front droop .
but another question, every time i exit the corne i acelerate and my rear end becomes loose . Its tail fishi . how could i improve that like i can get out of the corners without having my rear end to be going left right
Thanks again guys
Thanks again guys
I need some help from somebody. I am looking to purchase the updated sway bar mount for my cyclone black but can't see pdf's on my phone can somebody give me the part number? Thanks
