setup
Old 01-03-2017, 05:28 AM
Default setup
been fighting off power push car not rotating having to wait for the car to turn t4-16 what direction to look at
to slow for you is offline
Old 01-03-2017, 05:33 AM
Loco4G63T's Avatar
Trader Rating: 27 (100%+)
http://www.rctech.net/forum/electric...r-chassis.html
Check this out and hopefully it will give you a few ideas to try.
Loco4G63T is offline
Old 01-03-2017, 06:31 AM
Trader Rating: 26 (100%+)
could be anything from running a front spool, too thick of rear diff fluid, needing more toe, camber, caster, droop...it's a lot of factors. no one knows where to direct you unless you put up your entire setup
phatboislim is offline
Old 01-03-2017, 07:53 AM
ok
front droop 6mm
rear droop 5mm
front springs 2.5-2.8
rear springs2.6
shock oil 425 cst frt and rear
front sway bar 1.4
rear bar 1.3
shock locations frt 2hole out
rear shocks location 3 out
left and right balance ok
arm sweep front
rear toe 3.5 in
front toe total 1.5 out
frt spool
rear gear diff 6000cst
camber frt and rear 2.0 -
Old 01-03-2017, 08:02 AM
problem is worse when traction gets high black carpet
Old 01-03-2017, 08:03 AM
Originally Posted by to slow for you
ok
front droop 6mm
rear droop 5mm
rear springs2.6
front sway bar 1.4
rear bar 1.3
arm sweep front
rear toe 3.5 in
frt spool
Not sure what your track looks like, but the first thing I'd do is reduce that rear toe a bit. Maybe just move to the .5 out on the RF blocks. You could also try moving the rear shocks in one hole on the tower and fronts one hole out. That should make the car carve into the corner a bit better.
Pictures of your track and specific corners you're having problems with would also help us sort it out.
EDIT:
Black carpet I would DEFINITELY reduce rear toe. 3.5 is way too much for FT2.
Danny-b23 is offline
Old 01-03-2017, 08:07 AM
Trader Rating: 11 (100%+)
You didn't say what class, but if we're talking touring car the body also has a large role in entry and exit steering. The ltcr will have more entry steering and the mazda will have more exit steering.
I also think you have way too much rear toe for black carpet, but that doesn't change off power steering as much as it will on power steering.
anr211 is offline
Old 01-03-2017, 08:22 AM
ok
front droop 6mm
rear droop 5mm
rear springs2.6
front sway bar 1.4
rear bar 1.3
arm sweep front
rear toe 3.5 in
frt spool
generally i run 5.5 RH front and rear with about 1.5 droop over ride height. your rear diff lube sounds too thick, with some recent reading i went from 7k to 2k. i'm testing it out this weekend, but i could tell it was pushing me on exit.
also as was said above, go to 3* toe in on the rear and i wouldnt go beyond 1* toe out on the front.
ALSO front spools does have a tendency to push as well coming hot into a corner especially off a straight away
Old 01-03-2017, 08:45 AM
thanks i will try some changes
Old 01-03-2017, 09:23 AM
I don't run an x-ray anymore. But before I got rid of it on ft2 carpet the most rear toe I ever ran was 2.5°. and almost always I had 2°...
Jwilliams5 is offline
http://forum.teamxray.com/xsheets.php
Roelof is offline
