Hpi Pro 4
#8431
if you are looking for the most reliable and durable car.
hands down to pro 2. It's like a rock.
It has a lot of imperfection as stock ( what comes in the box and basic design), for instant the chassis flex a lot, if you think the flex in pro 4 is bad, pro2 is worse. For acceleration, it is not as good as the top end car on the market today.
but no doubt, it is a great car for beginner.
#8432
Trader Rating: 32 (100%+)
Rookie....maybe there is no offset on the Orion rim....and that is the problem. I know that some nitro foam tires do not have any offset in the rim. Carpet foam rims all have an extra 2mm offset built in I believe...so that might be the problem. Once you get some real carpet foam tires I bet that you wont have this issue. I have seen 30mm TRC foams fit the rear of the car so there must be something with the Orion rim.
#8433
Has anyone lost a D-clip retaining the shock guides and orings? What did you do to replace it? My lhs said they are on backorder. Is there something else that will work?
#8434
Re: front bumper
Originally posted by rai13
Does anyone know of an aftermarket wider front bumper for the pro 4? I keep braking hubs and i think a wider front bumper would help alot.
Also does anyone know if the rpm bumper for a Nitro TC3 will work without modifications? Can I just slip it under the foam bumper?
thanks in advance
rai
thanks in advance
rai
I know a lot of you have gone to aftermarket 3mm chassis sets for your cars on carpet, and I actually just redid my car with the HPI 3mm lower and 2.5mm upper deck. The car feels a heck of a lot stiffer than with the stock chassis. Until recently I didn't even realize HPI had a thicker chassis out there. Something to consider if you are going to swap plates.
Will have photos of the new shell and chassis set soon. Probibally by this weekend.
#8435
And I can't find anywhere online that has them in stock either....sure glad I ordered a pair as soon as I found them!
#8436
#8437
Thanks.
#8438
Hara's servo
Hi, just a quick question for you guys. Would somebody be able to tell me which KO servo Hara has been running recently? I saw one with a gold heatsink (i assume) band around it. just wanted to know which model it was...cheers
#8440
Originally posted by cartmen34
You know, that's the ONLY thing I don't really like about his car? I don't like the way the shocks seal assembly is designed.
#8441
Originally posted by Aurra Sing
You're right, the clips are a little hard to put in and take out, but the whole design of the shock is much more sealed compared to TRF shocks. After 4 races with the Pro4, i rebuilt the shocks expecting to see the oil blackened by dirt, but the oil came out crystal clear unlike TRF shocks after 4 races.
take care
john
#8442
Wanna ask something. Y my rear right feel gritty when i turn my differential and the left wheel feels smooth? is there something binding?
#8443
Re: Hara's servo
#8444
easy motor removal
Hi guys, i am a new owner of the pro 4 and simply wanting to know if anyone has developed any tricks for easy motor removal
There surely must be an easier way than an allen key...
Cheers
Michael
Cheers
Michael
#8445
when the wheels are done up too tight, they exhibit a gritty feeling
