The Speed Passion Thread >
Like Tree57Likes
Old 07-01-2013, 12:22 PM
  #11761
durtbag's Avatar
Originally Posted by SP Tech
Where did you purchase the ESC? Was this a Asian, UK, or other market outside of the USA?
Asian market, RCMart
durtbag is offline
Old 07-01-2013, 12:49 PM
  #11762
Sorry I cannot help you with RCMart Asian orders. Hopefully RCMart is referring you to your countries Speed Passion distributor.
SP Tech is offline
Old 07-01-2013, 01:30 PM
  #11763
durtbag's Avatar
Can't, won't, don't care....... I've heard them all before from SP.
We don't have a Speed Passion Distributor in Canada, nobody wants to deal with all the failures I guess.
Dealing with RCMart is worse than dealing with SP... well not really, at least they reply to e-mails.
durtbag is offline
Old 07-01-2013, 10:59 PM
  #11764
ta04evah's Avatar
Sounds a good time to switch to a esc manufacturer that offers support on genuine products regardless where it's bought from, and has official distributors in Canada.
Cheers
Rob.
ta04evah is offline
Old 07-02-2013, 09:10 AM
  #11765
durtbag's Avatar
Cheers
Rob.
Yeah, I already use Tekin and ORCA without any issues.
I get the feeling that the SP ESC's from RCMart may be counterfeit, thats why SP doesn't let you register them for warranty, and they tell you to go back to RCMart if you have any problems.
The only reason I went with RCMart was because the shipping to Canada was only $9, if I ordered it from SP USA they wanted $35 to ship. They claimed that there was no cheaper method when I questioned the shipping cost. That should have been my first reason too walk away.
durtbag is offline
Old 07-02-2013, 09:22 AM
  #11766
Xpress's Avatar
I have a Reventon Pro. Works great.....no problems. That is all.
Xpress is offline
Old 07-02-2013, 10:34 AM
  #11767
i bought my reventon pro with v3 motor combo from rcmart ($129 with free shipping is hard to beat!) i registered my esc on speedpassion.net without any problems!
the esc was really easy to program and setup, looking forward to test it on the track!
Bappe is offline
Old 07-02-2013, 12:58 PM
  #11768
Hi,
I am setting up my Speed Passion reventon pro for the 1st time in 13.5 boosted.
I was just wondering what the following mean in regards to boost and turbo?
1) Hybrid boost active, this ranges from 30% up to 100%. (in 10% steps)
2) Hybrid boost maximum, this ranges from 110k up to 150k. (in 5k steps)
3) Hybrid boost start rpm, this ranges from 3000 rpm up to 15000 rpm. (in 1000 rpm steps)
4) Hybrid boost delay, this ranges from 0s up to 0.8s. (in 0.1 steps)
415tam is offline
Old 07-02-2013, 03:25 PM
  #11769
looking at the recommended settings in programming turbo and boost for a 8.5, but unsure where to start regarding the gearing..
will be running om a fairly large asphalt track, would 6.6 be a good start in gearing? motor is a sp v3 8.5t
Bappe is offline
Old 07-02-2013, 05:37 PM
  #11770
Trader Rating: 86 (100%+)
looking for gearing for speedpassion v3 6.5t motor with tekin rs pro on tc6 touring car 120 feet straight. thanks
littlealex is offline
Old 07-03-2013, 09:59 AM
  #11771
my 8.5R motorshaft is bend, where can i get a cheap new one? (shaft/rotor/whatever i need to fix it). This one: http://shop.teamspeedpassion.com/com...rotor-super-7/ seems a bit expensive for a motor which only costs 10$ more.
Cody227 is offline
Old 07-03-2013, 10:12 AM
  #11772
Xpress's Avatar
$30 for a rotor is about what every brand costs. Maybe it would be better to pick up a motor? New stator, bearings, etc...
Just curious.....how did you bend the motor shaft?
Xpress is offline
Old 07-03-2013, 10:19 AM
  #11773
it rolled of my desk when i was soldering and fell on the ground.
Cody227 is offline
Old 07-03-2013, 10:23 AM
  #11774
Trader Rating: 15 (100%+)
Default Stock
I have a speed passion stock spec speedo and it has pretty much zero brake . Is there any way to fix it? Also I have the speed passion dyno programmer is it compatable with the spec speedo?
AARON YOUNG is offline
Old 07-03-2013, 10:24 AM
  #11775
Xpress's Avatar
Maybe check the oval forums? The guys I know that race oval go thru a bunch of rotors to find the good ones.
Xpress is offline
