The Speed Passion Thread >
Like Tree57Likes
Old 10-10-2012, 05:12 AM
  #10261
Originally Posted by Skitee
hmmm...it's not a clone it's an official OEM product.
If it looks like a carrot and smells like carrot then tastes like a carrot.... Guess what it is a carrot.
Yes it's branded as a muchmore, but has same features design n looks of the sp. I would happily call it a clone.
Same as hpi flux and hw v3 they are the same the flux is a clone.
Jampot is offline
Old 10-10-2012, 05:42 AM
  #10262
Originally Posted by Timbo99
K=1000
So until Iam corrected by the speedpassion techs on here,and running the esc myself,going from say,130K to 140K with a 10.5turn,I definitely notice an increase in RPM.
Running a 4.5 turn with 150K hybrid boost,(drrs set on 7),you can see the chassis flex it's that nutty.
I have run a 13.5 with the Reventon Pro,(s/p mmm motor),and it was a bit "coggy" down low,like zero to jogging pace but then it was fine.
I'm just trying to help you,and I think the K stands for the thousand revs.
Hope this helps
AND I hope the techs correct me if I'm wrong.
Cheers
Tim
Cheers mate. That ain't far short of what I think unless, like you, some soeedoassion tech head corrects me. You said a 13.5 was a bit coggy. Would it be best to wait for sp's 13.5 firmware or is the cogging so small ut ain't worth worrying about?
RSCosworth is offline
Old 10-10-2012, 05:57 AM
  #10263
Timbo99's Avatar
Trader Rating: 14 (94%+)
I would wait.
It shouldn't be long for the software to come out and to put it bluntly,I was prepared to have it blow up or whatever just for the sake of gathering more data on this combo,so I could answer most questions about the software from our club members,who,are kids and can't afford to throw away an engine or speedie.
( I was using my sons one lol).....just kidding
So wait a couple of weeks then go nuts!
All the best
Tim Phillips
Timbo99 is offline
Old 10-10-2012, 06:00 AM
  #10264
Timbo99's Avatar
Thanks Jampot,clone,copy....whatever..but "official OEM product"?
......oh please spare me...
Cheers mate
Tim
Timbo99 is offline
Old 10-10-2012, 06:54 AM
  #10265
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Nice find on the blaze and Silver Arrow V2 combo. Not sure I like the high Kv though, hopefully we get something down in the 1900 - 2100 Kv range.
I thought after the whole "its just a hobbywing" fiasco that the SP stuff would be its own non-cloned / OEM'd, whatever deal?
by the way, will there be any more software updates for the GT2.0 line of is 428 stuff the limit?
Cain is offline
Old 10-10-2012, 07:21 AM
  #10266
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Still have an unused MMM13.5 and 2 sensor boards for sale. PM if interested
L.Fairtrace is offline
Old 10-10-2012, 07:37 AM
  #10267
Timbo99's Avatar
Hey Cain,
I believe Howard told us a while back,after they get the Reventon stuff sorted,it's on to new software for the GT2.0.
However the 2.1 is finished,no more,none,gone,nada,fini.
Cheers
Tim
Timbo99 is offline
Old 10-10-2012, 08:56 AM
  #10268
Trader Rating: 17 (100%+)
Hey Cain,
Cheers
Tim
There will not be any update on the GT2 series ESC....done, over, no more.
Solara is offline
Old 10-10-2012, 10:18 AM
  #10269
i can't wait to get the new s/w for 17.5 motors....
gdcopbdcop is offline
Old 10-10-2012, 12:34 PM
  #10270
Originally Posted by bvoltz
Ok, but out of stock in the US....
Instock now
SP CS is offline
Old 10-11-2012, 01:26 PM
  #10271
TAMAK's Avatar
Trader Rating: 29 (100%+)
1 cell motors... What would I benefit with a 1 cell 7.5t Mod motor in say 2wd buggy? Mainly looking for a smoother bottom, and thought this may be an option..
TAMAK is offline
Old 10-11-2012, 01:47 PM
  #10272
M-Technic's Avatar
Trader Rating: 15 (100%+)
Your easiest path to smoother bottom end is just to go with a more mild motor, say a 10.5, and boost it more to retain the top end.
M-Technic is offline
Old 10-11-2012, 01:57 PM
  #10273
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
i have ran the 1-cell 7.5t boosted but in a TC and the power band is smoother top end felt the same as my 2-cell 7.5t,it was easier to drive with the same settings as the 2 cell motor.
Marcos.J is offline
Old 10-11-2012, 09:58 PM
  #10274
Trader Rating: 38 (100%+)
Default reventon pro issues
So I finally got a chance to put my Reventon Pro in my touring car and am running into major issues. I've updated the firmware on the programmer card and in the ESC and so far have tried Stock0 and Mod1 with the same results. Pulling the trigger nets no activity from the motor most of the time. If I roll the spur gear about a half turn and try again it works fine until I stop again. I thought it might be a sensor wire issue but 4 wires and 2 motors later there hasn't been a change in how it's acting. Just to be sure, I put the reventon S back with with the same battery/rx/radio/sensor wire/motor and everything works perfectly and is very smooth. With the Rev Pro it has the issue above and even when it works it doesn't sound very smooth. Has anyone else had this issue and does anyone have any ideas of anything else to try with it?
In case anyone is wondering, KO 408s rx, Futaba BLS351 servo, Novak Ballistic 17.5 motor. The entire setup has worked flawlessly with the Reventon S, the Novak Edge and Novak Kinetic ESC's so I'm quite certain it is something specific to the Reventon Pro.
linkless is offline
Old 10-12-2012, 06:22 AM
  #10275
Timbo99's Avatar
Default Software
Hi,
Quite a simple fix.
You can't run a 17.5 yet with the current software.It only is suited for motors UP too 10.5.....or lower turns (down to 4.5/4.0).
The software you need will be released soon for 13.5/17.5/21.5.
Just have to wait,shouldn't be far away.
Cheers
Tim
Timbo99 is offline
