Tamiya mini cooper
Novak's Edge 2s speeder can be used for brushless/brushed racing. I have a few of them, easy to use, as with any Novak unit.
Are you sure you aren't thinking of the Havoc? I have both Havocs and Edges, but only the Havoc instructions cover brushed (and it works well, although it's very large for a Mini). Is brushed operation a hidden feature in the Edge?
Thanks!
Yep, you're right. My bad! I have both and got the two mixed up.
Shopping for spare parts to make waterproofed so I can drive in the rain. What specs should I look for in a servo? or shouldn't I worry about it getting wet?
Traxxas makes a line of waterproof servos. That might be a good place to start. Your best bet would be to find a video or two on waterproofing RC electronics for trail trucks. There are techniques that are as simple as stuffing things into balloons to complete tearing stiff down to encase it in epoxy. I just avoid water. haven't blown anything up since the puddle incident of 2008.
Savox also makes waterproof servos. None of them are exactly speed demons but should work ok on these. I use them on my scale trail rigs.
Hey guys, big question about small parts: How does camber affect top speed? I'm running the stock, solid upper links on my M03. At the very low ride height we tend to run, they give a fairly insane amount of camber. I know this is generally good for cornering and bad for tires, but does it have an effect in a straight line?
I'm generally happy with my setup (crude as a rock). It corners very well as is. I've got a complete set of adjustable uppers I'm hesitant to install. How do you guys see it?
3racing dif gear set or ta03 dif set ... do you need extra bearings to install in a m05 complete?
I've got some ideas. Just looking for perspective.
For the TA03, no. For the 3Racing you'll need a couple 10x15x4 bearings.
Theoretically, yes. But taking tire wear out of the equation, what does it do? EG: Two cars bombing down the back straight, one with loads of camber, the other with almost none, how will the top speed of either be influenced?
If your M chassis is getting passed on the straight....it isn't camber. IMO.
Tried, but failed, to go club racing yesterday. Last chance for me for a month probably.
