Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 06-03-2008, 07:34 AM
  #6076
Rick Hohwart's Avatar
Originally Posted by beanster
Rick thanks for sending me the set up so quickly. One question I have is what is a slipper spool?? is this a stock diff ran tightly?? Thanks Matt
The slipper spool comes stock in the new TC5 kits. The slipper spool uses normal diff parts and outdrives, but the standard diff rings are replaces with slipper spool pads. When locked down, there is no slip other than some small give when you take a hard front end hit. This give protects prevents the blades from breaking and chewing up the outdrives.
There is no difference in performance or feel between the standard spool and the slipper spool.
Rick Hohwart is offline
Old 06-03-2008, 08:04 AM
  #6077
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hey Rick...any aluminum rear hubs in the works? What about tougher caster blocks? That seems to be the weakest point in the car, and they are very thin compared to others it seems to me. Will this be updated or its not something AE feels is an issue at the moment?
yyhayyim is offline
Old 06-03-2008, 08:32 AM
  #6078
Trader Rating: 38 (100%+)
I only race 10.5 but Ive never broken a part on the car (in 6 months) other then the CVD blades. Ive since gone back to the plastic outdirves and a JAAD racing spool up front and not had problems. I think the car is very strong. In Mod I think there is always going to be a weak part. Something has to give.
or8ital is offline
Old 06-03-2008, 08:42 AM
  #6079
yyhayyim's Avatar
My buddy Sonic31 runs his Tc5 with the new JAAD spool and P-Dub bumper and its nice...should defenitely help the car hold up much better. The only thing he's broken in about 3 months of weekly running with it is a C-hub...light tap at bad angle...the C-hubs just look very thin compared to other cars, and just wondering if AE thinks its something worth looking into
yyhayyim is offline
Old 06-03-2008, 09:03 AM
  #6080
I have found that when I break a frot end part, it is the arm rather than the caster block. But the hard caster blocks definitely seem stronger.
We are always looking at improvements but I am not sure exactly what the engineering department is up to but I think the front end are can always be stronger.
I don't use one, but from what I have heard, the P-Dub bumper is very good at preventing breakage in the front end.
Old 06-03-2008, 09:04 AM
  #6081
dbmartin's Avatar
Trader Rating: 11 (100%+)
I can email it to anyone who wants it. It will also be posted on AE's site eventually.
[email protected]
Many Thanks
dbmartin is offline
Old 06-03-2008, 09:07 AM
  #6082
K_King's Avatar
Trader Rating: 47 (100%+)
So is the team running the hard caster blocks now for rubber racing?
K_King is offline
Old 06-03-2008, 09:42 AM
  #6083
I am because I think they work better. I would use the soft ones if I thought they were an advantage.
Old 06-03-2008, 09:44 AM
  #6084
Hi Rick H! I would love a copy of that Reedy setup as well. Converting the car back to asphalt...Thanks
[email protected]
BillySnarf is offline
Old 06-03-2008, 09:50 AM
  #6085
losithrasher's Avatar
hey rick, may i get a copy my self? thanks a bunch
josh
[email protected]
losithrasher is offline
Old 06-03-2008, 09:54 AM
  #6086
That is a good point. I am running the p-dub bumper. Im sure it helps a lot. Plus the way the bumper in general attaches to the TC5 I think it holds up better.
or8ital is offline
Old 06-03-2008, 09:56 AM
  #6087
where can u get the p-dub bumper, every time i go to the website, its out of stock.
Old 06-03-2008, 10:25 AM
  #6088
Here you go:
http://www.nexusracing.com/product_i...a73eac89daab88
or8ital is offline
Old 06-03-2008, 10:53 AM
  #6089
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
I found that I need to shave the P-Dub bumper quite a bit to get it to fit under a shell, specifically my Mazda 6, however it is still worth the cost IMO.
rezenclowd3 is offline
Old 06-03-2008, 11:47 AM
  #6090
Ive used it with a Speed6 and Mazda6 and not had to shave anything off the bumper. Its a perfect fit. That is for rubber tire though. Not sure about foams. Which were you referring to?
or8ital is offline
