Like Tree6Likes
Tamiya Ta06
Old 12-31-2011, 11:49 AM
  #1486
samshirley00's Avatar
I only put it in upright mode, because I got my shocks pre-owned and assembled, and I couldn't be bothered to disassemble them and make them IFS. I usually have a standard touring car body on anyway, so its hardly an issue.
There are only 2 people running a TA06 at my club, and I am one of them. Most of the line-up are modified TA-05 IFS's and the majority are TT-01's still, but there is the odd xray something and even a Schumacher Mi4CX Pro in the highest heat.
samshirley00 is offline
Old 12-31-2011, 12:38 PM
  #1487
TA06 blank and editable setup sheet available on petit
Arn0 is offline
Old 01-01-2012, 04:18 PM
  #1488
cementsurfer86's Avatar
Yeah my buddy and myself are the only ones running the '06 at the local track, and I believe there is only one other guy running a Tamiya in the whole club, and I believe it's a '05 IFS. It's mostly a Xray/Associated crowd.
cementsurfer86 is offline
Old 01-01-2012, 11:33 PM
  #1489
Does anyone have problems keeping fluid in the rear gear diff? I ran two battery packs and I already have fluid leaking. I'm currently using 3k and used green slime on the o-rings. Any tricks out there?
Old 01-02-2012, 12:50 AM
  #1490
I have had the same trouble, ended up sanding flat the diff gear then using grease on both sides of the gasket. It helps but not sealed completely.
DA_cookie_monst is offline
Old 01-02-2012, 07:09 AM
  #1491
i got an epic precision screwdriver set, with a 1.5mm hex attatchment on it, so i can tighten those annoying screws on the dif properly, so i don't get any leakage now....
Old 01-02-2012, 12:20 PM
  #1492
silverhkswrx's Avatar
I just 'the hell with it and went with a ball diff and havent looked back.
silverhkswrx is offline
Old 01-02-2012, 01:11 PM
  #1493
is there a DIY that shows how to put dif putty in the front difF?
Profoxcg is offline
Old 01-02-2012, 03:43 PM
  #1494
I use black AE grease in it. Works great and no leaks.
Juan Aveytia is offline
Old 01-02-2012, 03:45 PM
  #1495
Default speaking of front diff
anyone tried a one-way on concrete?
I am thinking about investing in one if the car doesn't sell.
Also,
How are you guys getting 190mm track width? My car is short unless I use HPI 3mm offset wheels. I am already using 5mm tamiya hubs.
I would like to run this car in TC,
Profoxcg is offline
Old 01-02-2012, 08:35 PM
  #1496
Yeah I just rebuilt mine with the black grease, seems like it seals better. My problem has been with the o-rings, not so much with the gasket, that has been leak free. I coat both sides of the gasket with diff fluid. That seems to work good.
Old 01-02-2012, 11:11 PM
  #1497
190mm is a maximum width, and you use it as a tuning aide.
Old 01-03-2012, 03:28 AM
  #1498
well, i ordered some 7mm offsets yesterday, so i can have a go at monting some of the more intersting bodies, like that HPI Silverado racing pickup, or even a chevrolet nomad '54
Old 01-03-2012, 06:43 AM
  #1499
I only use AE grease and pack it in the diff heavily.
Old 01-03-2012, 06:45 AM
  #1500
I need a help. I'm trying to order from Eagle Arts Japan. Is there an English version site? Thanks in advance
