Tamiya F103 Forum
#1366
jeez,that 201 looks huuuuge. i am new to rc f1.i picked up a 103 a few weeks ago and have finally got it up and running. had my second track session today with it. am really enjoying the ddrive style chassis. i have a question tho,i am finding my chassis is rubbing on the ground on right hand turns but not on left.i assume it has something to do with the t plate and suspension setup? could anyone help a noob out and point me in the right direction for syspension set up.
cheers
cheers
#1369
Check to see if the chassis is tweaked by running a ruler bilaterally across the chassis plate. And by looking at the chassis on an even plain you should be able to see any tweaks in the chassis.
#1370
cheers
cheers
If you have the ball mount, has limiter screws?
#1371
Is the side to side movement equal with the body off?
How bout with the body on?
Many times, squeezing the body on puts pressure on motor wires etc.
Can jam the chassis to one side.
Check for free movement, leave the motor wires etc. loose and not tied to the chassis which can restrict pod movement.
#1373
Put it on carpet with foamies and it woulda loved the 14T
#1374
Hi Guys I still preparing my F103 15th for one italian Championship
With fixed body, tyres, esc and motor.
We will use I think a Mon-tech bodies
The F fro F104 and the J for F103,Enneti Tires with one painted ring,Hobby Wing 35 amp Esc and one no Mechanical timing engine 17,5 turn.
Any one can tell me the difference between the ABC diffusers?
Thanks for all!
Thanks for all!
#1375
Mon-tech bodies ?
Can you link us a pic of the f1 bodies they offer?
#1376
#1378
#1379
#1380
Always wondered what a 109 would look like with an "m" body-;I like.
