TLR 8IGHT E 3.0 THREAD
#1396
Tech Prophet
Again one shaft or different locations.
I have seen where shock shafts don't get deep enough threads on them and will not properly bite on the ends. Really hard hits something is going to give as well. Better a shock end then a bent shock shaft or something like that.
#1397
I've decided to run 1400kv with 6s in my E, I think. But what I can't find is the specs on the battery tray. I want to know what physical size battery will fit in the car nicely. I assume most will based on the video about how versatile the battery box is.
Can anyone give me the width and length in mm of the tray?
Thanks...
Thanks...
#1398
Thanks...
Thanks...
#1400
Front End Upgrade Parts
The UPS man brought me a nice $70 box from A Main Hobbies yesterday - containing the TLR3510 Front Overdrive Gear Set and the TLR341000 Brass Weight System.
Looks like a simple enough upgrade to get some more front end grip from my Losi 8ight 3.0! Every little bit helps!
Robert Conner
Omaha, Nebraska
Robert Conner
Omaha, Nebraska
#1401
Robert Conner
Omaha, Nebraska
Robert Conner
Omaha, Nebraska
#1402
Overdrive Ratios
The center diff can handle all sorts of power differences from the constantly changing loads of the front and rear diffs. That's what it's supposed to do. A .077 near-constant difference shouldn't even be detectable.
Robert Conner
Omaha, Nebraska
#1408
3.0 Manual
Hey Does anyone know if the 8 3.0 manual that comes with the kit has a setup guide like the old kits did? I bought a used kit and printed off the manual on the tlr site and it did not have any set up guide...
#1409
Basic setup: http://www.tlracing.com/ProdInfo/Fil...dard_Setup.pdf
Blank sheets: http://www.tlracing.com/ProdInfo/Fil...lank_Setup.pdf
#1410
Anyone have any pics of their car ready to run?
I was looking at my wiring last night and routing, just curious how a few of you have set yours up? Forgot to order a longer sensor wire so looks like another week before I can get out and run it. Also, where are you mounting your transponder with the radio box? Anyone running a HOTWIRE?
Other than soldering and painting the body, I'm about ready to practice and start racing again..
