Hot Bodies Cyclone
-Korey
We got these cars rocking out here bro. Scotty's set up is dialed. All we want to do now is test the new proptoform body and see how it runs on the car. I have been going back and forth with the regular mazda 6 and the AP stratus. The DNA 2 was my body of choice last year but it turns in way too hard with our current set up. I think I'm only going to run 13.5 for the rest of the year. Mod is hit or mis around here.
so i'm also see to body shell , do you have understeering first ,
if not have will change steering parts ,
pump steering , ackerman , F & R drop ,
i'm alway in bump steering shim 1mm , in mid corner Apex don't lose steering feel & can keep use small steering for more turn .
if in hairpin maybe will have max turn only .
well no it has a bit of oversteer thats wy im trying to find a solution to corner faster without the rear end to spin
Thank you
Thank you
im running MOD 5.5 .
And how do i change the toe in angle at the rear of my car if .Does it have to be changed with the toe block or can it be changed with anything else for the rear
can't setup Rear or Front only !
if you Spool , you can try F - kick up ( FF 0.5 FR 1mm or FF FR 1mm ),
Rear downstop more drop ( smaller flow )
5 or 6 cell ?
Just finished in a elecronics store here...is it bad that I am excited I founds purple zip ties?
does the brushless motor mount raise the motor or move it forward?
i have a Andy Moore wce with a 13.5 Novak and the motor seems to be sat on the chassis
Kev-h
Kev-h
The motor is in the same place,, The BL motor mount raises the lay shaft 2mm so you have room for a spur that is 4mm larger. They should call it a brushless lay shaft holder thingy
does that not stop the heatsink middle chassis sitting square?
is it normal for the motor to be on the chassis?
With the BL mount you use two 2mm shims on the rear balk heads under the rear top plate and it sets flat.
I have two chassis, one is BMI and the motor sits right on the chassis on both of them.
Your Welcome
Your Welcome
