Speed Passion  F1 car - The SP1 >
Like Tree4Likes
Old 08-10-2015, 10:38 PM
  #1396
Schs2013's Avatar
Is the new SP-1 v2 out yet?
Schs2013 is offline
Old 08-12-2015, 07:25 AM
  #1397
antonio_cadiz's Avatar
hello!
If I change this bearing http://shop.speedpowerrc.com/11x5mm-bearing/ for this other http://avidrc.com/product/1/bearings...-bearings.html get more softness in the differential?.
sorry for my english
antonio_cadiz is offline
Old 08-12-2015, 05:40 PM
  #1398
The thrust bearing will last longer as it handles the pressure better...but the bearing race that comes with the car will have better differential action.
InspGadgt is offline
Old 08-16-2015, 04:58 PM
  #1399
adriang79's Avatar
It's becoming rather difficult to source some of the parts for the SP-1 now. I have some spares, but don't have a spare "football"
Looks as though I may need to retire my SP-1 due to this. A real shame, as I do love this car, won the F1 class at my club this weekend, beating a pair of Xray X1s
adriang79 is offline
Old 08-16-2015, 05:23 PM
  #1400
evochick's Avatar
I am 99% sure the pivot ball/mount and side links share the same dimensions and are a direct replacement with Associated RC12R5 and Yokomo YRF/R12, I am sure I have lent one to a Speedpassion driver before.
part number YOKR12-21L or ASC4635
if you send me the hole distances I can check for you tonight to confirm 100%
evochick is offline
Old 08-16-2015, 05:29 PM
  #1401
adriang79's Avatar
The side links are certainly a direct replacement, I am currently using them as they are much better than the standard links.
As for the pivot ball/mount, well they don't fit (I just double checked with the one I have) the holes are too far apart
Old 08-16-2015, 05:37 PM
  #1402
evochick's Avatar
bummer, ill double check tonight the Yokomo one just to make sure its not the same as the Associated.
Are the holes too wide on the chassis or too wide on the pivot ball ??
evochick is offline
Old 08-16-2015, 05:40 PM
  #1403
adriang79's Avatar
Too wide on the pivot.
Thanks, I will be keeping my fingers crossed
Old 08-17-2015, 01:16 AM
  #1404
evochick's Avatar
you learn something new everyday, the associated pivot mount is 35mm between the middle of the outside holes and the Yokomo one is 32mm,
I just always assumed they were the same, so the million dollar question is what is the hole spacing on the speedpassion part ??
evochick is offline
Old 08-17-2015, 02:49 AM
  #1405
adriang79's Avatar
oooohhh, just measured the speed passion, measured up at 32mm Looks like we have a match!!
Thanks for checking that out for me
Old 08-17-2015, 03:35 AM
  #1406
evochick's Avatar
That's ok, as I said I was sure I have put one in a speedpassion car in the past,
The Aus importer has them in stock so should be easy enough to order in
evochick is offline
Old 08-17-2015, 03:45 AM
  #1407
adriang79's Avatar
Fantastic, I will have to get onto that then. Was the only part that generally can break that I couldn't source from something else. F104 front end would fix most of the other parts availability issues of course
Old 08-17-2015, 03:50 AM
  #1408
blade072's Avatar
Trader Rating: 98 (100%+)
i have an sp1 which is in bits at the moment but have bought most of the option parts to suit plus some spares....comes with a spektrum servo.......dont think ill get a chance to run it to be honest.....if anyone is after one for spares or a second car let me know
thanks
blade072 is offline
Old 08-21-2015, 07:07 AM
  #1409
aris's Avatar
Can someone please help me
I'd like to get the Pit tires but i'm not sure what rim to fit on them.
I thought i saw it somewhere here.
aris is offline
Old 08-21-2015, 09:50 AM
  #1410
JayL's Avatar
Tamiya 51378 is the black version
It is confusing but the Pit rubber tires mount on the Tamiya Foam rims
JayL is offline
