Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 10-29-2012, 07:00 PM
  #13141
Losiho's Avatar
Originally Posted by nuttynative
Probably been asked and answered a few times. Will the TC6.1 gear diff work in the TC5?
Someone else can confirm this, I'm 99% sure they will not fit. The gap between the bulkheads are much wider on the TC5 compared to the 6 / 6.1.
Losiho is offline
Old 10-30-2012, 08:11 AM
  #13142
How about this ?
mos-leung is offline
Old 10-30-2012, 08:37 AM
  #13143
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
Buddy of mine runs 1 in his TC5 as well. Said there was no fit issues.
Flying Monkey is offline
Old 10-30-2012, 03:23 PM
  #13144
nuttynative's Avatar
Trader Rating: 11 (100%+)
So, I'm guessing that if the gear diff will work. So will the 6.1 spool hub?
nuttynative is offline
Old 10-30-2012, 11:47 PM
  #13145
wtcc's Avatar
The only difference is the distance between the bulkheads. So if you use shims every one way, gear diff, slipper spool, ball diff will fit.
The new TC6.1 spool will not be a pure drop in because the outdrives are mounted seperatly. So there you have to be creative. I would recommend the slipper spool if you are not able to get a TC5 spool (what should be no problem...).
wtcc is offline
Old 11-02-2012, 09:56 PM
  #13146
I just got a TC5 last week and am trying to find out what all came stock on the car. Specifically the caster blocks and rear hub carriers, are they 0 or 2 degree? The TC5 and TC6.1 have the same rear a-arms so I'm assuming the 6.1 rear hub carriers will work on the TC5, is this correct?
Old 11-03-2012, 02:37 AM
  #13147
wtcc's Avatar
That is wrong. Only the TC5 and the TC6 have the same suspension parts. The 6.1 got new parts. I am not completly sure if all of them are interchangeable. I know that the C-Hubs are!
The TC5 came with 4* C-Hubs and 0* rear hubs.
wtcc is offline
Old 11-03-2012, 01:48 PM
  #13148
Originally Posted by mos-leung
How about this ?
http://www.rctech.net/forum/attachme...5-img_0393.jpg
Looking at your picture I see you put the TC6 gear diff in backwards. Did you change the belts position on the spur gear and flip the front diff to.
What's the reasoning?
I notice the gear diff moves from side to side when in the car on the bench.
maybe shim it up.
chongo is offline
Old 11-10-2012, 09:01 AM
  #13149
DOTHOPPER's Avatar
Glad to see guys running the TC5. I have a damn near brand new car that I have ran maybe 3 times since it was new and it has sat for the last 3 years. I know the the Sphere TC spec is not legal so it's out but what else should I do to the car other than lipo cups and a gear diff to make it run a little better ?
DOTHOPPER is offline
Old 11-12-2012, 12:39 PM
  #13150
First off what class are you running?
Lots of good setups throughout this thread and on http://www.teamassociated.com/cars_a...anuals_setups/
Lipo cups? I just use the AE tray and tape in my battery.
chongo is offline
Old 11-12-2012, 08:00 PM
  #13151
Gundevil-81's Avatar
I don't even use the tray, just tape
Gundevil-81 is offline
Old 11-15-2012, 08:35 AM
  #13152
DOTHOPPER's Avatar
Will be just 17.5t stock intermediate will be carpet/asphalt/parking lot.
Old 11-16-2012, 04:27 AM
  #13153
Hey
For me i put the option front spool and a yokomo bd5 gear diff which drops into the tc5 with the correct shimming.
I havent tried it just yet but if you want to take the next step you can even put tc6.1 arms all round tc6.1 knuckles c hubs and reab hubs
I also added TRF shocks because i didnt like the standard shocks
Let me know how you guys go
AleD123 is offline
Old 11-16-2012, 02:26 PM
  #13154
Try this one it's a carpet setup.
Rc pete is one of the best racers around here and is the go to guy for setup help at our track! He's also an AE team Driver.
I use one of his setups very similar to this one.
http://www.rctech.net/forum/7144957-post12100.html
I just dropped in a tc6 gear diff and shimmed it up in mine with a slipper spool up front.
If you flip your diffs around it will move the front belt to the right side of the car allowing for more room for electronics. like in mos-Leung's picture above.
chongo is offline
Old 11-17-2012, 09:05 AM
  #13155
DOTHOPPER's Avatar
How about the shocks ? have you guys upgraded them ?
