Durango DEX210 Thread >
Like Tree80Likes
Old 03-17-2012, 06:16 AM
  #4906
dexon555's Avatar
Default TD Kit Availability
I read that everyone is having trouble getting TD kits. I visited my two LHS and they had kits galore. They had DEX410v.3, DEX210 and DESC410R in stock and on the shelf. RC Hobbies in Tamarac and Hobby Super Store in Plantation, Florida. They both have web-sites.
dexon555 is offline
Old 03-17-2012, 06:43 AM
  #4907
The Juice's Avatar
Trader Rating: 25 (100%+)
I didnt think it was kits so much as it was parts....
The Juice is offline
Old 03-17-2012, 07:28 AM
  #4908
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Tim, what classes are you gonna race today?
CHIZZLE is offline
Old 03-17-2012, 08:15 AM
  #4909
dexon555's Avatar
Default TD Parts
Both stores stock lots of parts too.
dexon555 is offline
Old 03-17-2012, 03:52 PM
  #4910
Trader Rating: 125 (100%+)
It was soo unseasonably warm today. Got to dust off the 210 and joined a bunch of buddies at the local outdoor track.
Didn't have any front wheels to mount ribs so I had to use indoor barcodes up front. Happy to say handling was good even without the right front tires. Can't wait until next test n tune when I have the right tires.
No popped ballcups or broken tranny cases.
kwiksi is offline
Old 03-17-2012, 05:13 PM
  #4911
rcman182006's Avatar
Trader Rating: 15 (100%+)
Finally got some pictures of my new Finnisher body by 5 Star Designs
Attached Thumbnails Durango DEX210 Thread-dscn2973.jpg   Durango DEX210 Thread-dscn2974.jpg
rcman182006 is offline
Old 03-17-2012, 05:34 PM
  #4912
Trader Rating: 79 (99%+)
Im loving my car... You need some "RED" stuff on your car. Check out www.Tresrey-usa.com
Raul Garcia is offline
Old 03-17-2012, 09:43 PM
  #4913
Trader Rating: 520 (100%+)
I like it rcman, I painted a lid for my car this week also..Never mind the wing or rear wheels, they are transplants until I restock..
I need to get some red bling this week..
flame56mx is offline
Old 03-17-2012, 09:48 PM
  #4914
Originally Posted by Synergy
Finished the ball diff build and going to do RM3 does the diff screw need to be install a certain way?
Some say this or that, I always install mine so the adjuster on the drivers side-nut on the passenger side. I have never had a problem with it ever..
Old 03-18-2012, 05:28 AM
  #4915
Well, I started installing my MOS shocks. First, I Luv the color. They are super smooth. Your original cap, cap oring, lower cartridge cap, and ball socket with bumpstop needs to be transferred. I built mine the same as my kit shock, OMG, the difference in feel from one to the other. I can't wait to hit the track.
Old 03-18-2012, 05:35 AM
  #4916
The Juice's Avatar
Any suggestions for more off power steering? Cant get it to rotate around tight enough.
Old 03-18-2012, 05:37 AM
  #4917
What is your setup?
Old 03-18-2012, 06:39 AM
  #4918
The Juice's Avatar
What is your setup?
Been trying different things but right now I have
Front -2 camber
Dark Green spring
1.3x4 piston with 35wt losi
Mounted in the middle up top and inner down low
+1 washer to raise roll center
Little bit of toe out
Rear
-1 camber
Light red spring
1.2x4 piston with 25wt losi
Stock toe in
Full size battery is all the way forward. I moved the inner steering link forward from the middle and maybe got a little better turning. Also tried moving the shocks to the outer mount with no change. Raising the roll center helped a tiny bit. Tried all these by themselves. On power seems decent but if I overshoot a turn and let off it swings wide.
Old 03-18-2012, 07:05 AM
  #4919
Front -2 camber
Dark Green spring
Rear
-1 camber
Light red spring
Stock toe in
Have you ever tried a shorty? This car responds better top a shorty than any other car I have driven..
Old 03-18-2012, 07:14 AM
  #4920
Matt Howard's Avatar
Front -2 camber
Dark Green spring
Rear
-1 camber
Light red spring
Stock toe in
how much anti-squat in the rear? usually more anti-squat will let the car rotate better in the corners
Matt Howard is offline
