Hpi Pro 4
Originally Posted by bxpitbull
What does TRJ and a cockroach have in common? No matter how many times you squash them, they refuse to die!
Hey BXPITBULL,
Originally Posted by trjracing
Hey BXPITBULL,
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Mamba Max Gearing
Hey guys , can you help me on best gearing combination.... I'm going to get a Mamba Max 6900. What is the best spur and pinion combination, 64 or 48 pitch. ... running on a large flowing asphalt, low traction, track... also on a technical track. Cheers
I would start with....
I woud stick with 64 pitch. Starting with the 98t spur, go with a 28t pinion and work your way down, The 6900 isnt as ballistic as the 7700, meaning that it will give you nice torque off the line without being overly aggressive. Checking your motor after say 10 minutes (you are running Li-Po right?), if your motor can is warm but not hot (120 degrees or so), it all depends on the top end. If you like what you see, stay there. If you want a little more top go up a tooth. More punch less top, go down one. Rip em and kill em!
Bxpitbull you get my message?
Bxpitbull check your pm.
Bxpitbull is your PRO4 ready???
Its dead here. No one likes PRO 4's???
@trjracing, please stop spamming the threads, you've made 4 utterly useless post in the past hour!! you cant expect everyone to be at your beck-n-call ... wait a day for a response or just edit your last post.
Does any one need help anyone in need of tech support???
