Vision Racing Products (VRP) >
Like Tree27Likes
Old 11-05-2016, 08:52 PM
  #196
JAE
Trader Rating: 30 (100%+)
Default V2 vs EU pistons
Which ones for medium to high bite clay US tracks? Thx
JAE is offline
Old 11-07-2016, 05:59 AM
  #197
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
Originally Posted by CCristo
Does VRP offer a long B6 rear tower for use with the 31mm shock bodies?
Not yet, we are working on it though. We hope to release it very soon.
"Smiley" is offline
  #198
"Smiley"'s Avatar
For the B6, it mainly depends on what setup you are currently using. I personally run gullwing up front and shocks mounted on front of rear arms. I run EU 3x1.4 front and rear 32.5/30. For me, its a very easy to drive setup that you can get aggressive with.
"Smiley" is offline
Old 11-07-2016, 07:55 AM
  #199
JAE
Difference between v2 and EU? Thx
JAE is offline
Old 11-08-2016, 06:06 AM
  #200
"Smiley"'s Avatar
The XV2 are used on your typical dirt track. Low to med bite. The EU are used on high bite clay and carpet tracks. The EU has a modified sidewall of the piston that reduces friction but maintains the same amount of pack. These work really well on high bite tracks.
"Smiley" is offline
Old 11-08-2016, 06:30 AM
  #201
Cain's Avatar
Trader Rating: 294 (100%+)
can you elaborate on this?
reason I ask is that just by what was stated about the EU it sounds like its better than the xv2 (reduced friction, same pack). What specifically about the XV2 makes it better than the EU on dirt?
sorry trying to understand
Any more news on when the tall rear AE tower will be released?
Cain is offline
Old 11-08-2016, 10:42 AM
  #202
"Smiley"'s Avatar
The EU has a slim sidewall that reduces friction. The XV2 has a normal sidewall that creates more friction than the EU, but the pack remains the same. The EU having less friction has been tested and proven to perform better on high bite tracks. The less friction on the sidewall of the shock body just tends to be more stable in high bite conditions.
The tall rear tower will be ready soon. We are hoping for next week.
"Smiley" is offline
Old 11-08-2016, 11:38 AM
  #203
Cain's Avatar
thanks, so basically the same other than the friction you mentioned.
Cain is offline
Old 11-08-2016, 01:04 PM
  #204
I just ordered some 2x1.6 for associated v2 for a high bite clay indoor track. I hope I don't regret not getting the EU version. I like the 1/8th pistons so I got high hopes on these 1/10 pistons.
racingnewb is offline
Old 11-08-2016, 01:16 PM
  #205
"Smiley"'s Avatar
Exactly
"Smiley" is offline
Old 11-08-2016, 01:17 PM
  #206
"Smiley"'s Avatar
You will be fine with what you ordered. Its all personal preference really.
"Smiley" is offline
Old 11-09-2016, 10:48 AM
  #207
Thanks smiley
Old 11-09-2016, 01:02 PM
  #208
"Smiley"'s Avatar
No problem
"Smiley" is offline
Old 11-11-2016, 05:44 PM
  #209
walterheard's Avatar
Trader Rating: 31 (100%+)
22t 2.0 owners... What pistons and oils are you running ?
walterheard is offline
Old 11-14-2016, 01:14 AM
  #210
JAE
I have 1.6x2 front and 1.4x3 rear in EU Pistons as recommended to me awhile ago but can't remember why.. Also have an additional 1.6x2 I can use for rear as well. Run med/high (Ocrc) bite clay. Running stock buggy. Should I keep these or try the v2? Also, should I stick to the 2 hole all around and what is the advantage of 1.4x3. Thx much!
JAE is offline
