Tamiya TB-Evolution III
#781
Kai Conversion Kit
Anybody would like to get the Kai Graphite Kit for EVOIII? Drop me a pm to discuss.
#782
Wow, you make your own Graphite Kit ?
#783
#784
FoamPervert : Dude, you can put almost any respectable RC car in Nicholas Lee's hands and he will make us mere mortals look bad :P I presume the other Evo3 in the A mains on Sunday in CCK was Ray Lan? How did he finish?
Heheheh dude, you blame ur skills???? heheheheh time to lay off the Starbucks Double Expresso, that stuff makes ur hands twitch heheheheh.
Cheers
Cheers
#785
Itchy,
Thanks for the compliments on the TL01 - yeah it did go OK except for the collapsing of the internal droop limiters which made the car go "off" in the second heat (It had 15mm droop at the end of the race!) .
But I did get the Evo 3 on pole on the first meeting out (yes I was running two cars in the one class!) , and that's a really nice feeling especially against the level of competition having two different cars in the A.
The Evo 3 seemed to go really well on the kit set up - all I had done was put the 2mm spacers under the rear suspension mounts. When it gets hot and grippy I am thinking of giving David Jun's carpet setup a try - nothing to loose.
Daf
Metro Hobbies Racing
Model Racing Technoogies
Team Orbital
Daf
Team Orbital
#786
Thanks Fangio and rtypec,
Glad to know there were other circumstances behind Tamiya not being at the Birds'. Truly unfortunate that they had no presence....as I said,the rumours and snide comments were in abundance. I hope the bugs are being worked out and the TRF guy's have an oppurtunity to prove themselves.
I've been hesitating to buy the 3 because of these diff problems. Has anybody heard something definite about a FACTORY fix?? Is anybody running a 3 in TCS with the aftermarket diff pieces?? Thanks, Dino
#787
evo 3 up and running
Hey guys I just got my evo3 together and I am about to do some extensive testing. I did put two runs on it with a stock motor and b2 tires on carpet, and even with the b2's if felt the car handled pretty well. I am not a fan of one ways on shaft cars, but I must say that it wasnt that bad. The car had a little to much push for my liking, but I think tires will remedy this minor problem. As for speed I had no problem at all with straight away speed, I was running a monster stock with 96/37. The car was fast and run time was awsome, still going to play with gearing variables to see were the limit is. The one thing that I noticed about the kit was the quality of the bearings. The m2 has a way better quality of bearings. I soaked them in lacquer thinner and oiled them up with airtool oil and they got a little better, but I think I will replace them with better grade bearings.
#789
ray. right now I am only going to run rubber tires on the car so that I can prepare for the tcs race in wisconsin in a couple of weeks, and after that I will try the foams, I am not in the mood to chase setups between foam and rubber before this race. I still need to experiment with gearing and mod motors so that will be the focus of my testing. I am planning on going up to larry's after work today to do some testing. By the way, did you end up getting an extra front diff for the car and were did you get the parts from.
#791
THANKS.
I have an f201 as well and was wondering if the diff halfs were the same if so then I have the parts to make up a diff.
#793
96/37 for monster mrodney ?
You are overgeared!It will be fast but not the punch you should expect.Try 96 33/34 and watch the motor come alive.What your geared at is like starting you car in 2nd/3rd gear.You will eventually burn it up.I have run my evo3 for a month and a half with this motor on rubber/carpet and this is where you wanna gear it.Try it,you will love it.By the way guys,these tamiya bearings suck so bad.Replace them if you just bought the car and if you can afford it. This is my only disappointment.Front spur I can live with.
#795
hey racenut I ran this gearing in the car for a few runs and the motor was not hot, I ran for about six or seven minutes and acceleration seemed pretty good. All things depend on the track layout. The track I was on was a smooth and flowing layout so bottom end wasn't as important than smooth entry and exit. I used to run a modified tbo1 and am still running an m2 and I can tell you that gearing 96/34 at our track doesnt seem to come close to being competitive. Heck on day a guy with a tc3 ran a 104/39 and just smoked us all. We thought he had a mod motor in that thing but he was running a monster. Now I am not suggesting people go on gear this way, because this guy was a factory driver and could afford to burn up motors,because he has plenty to play around with, but this gives you an idea of what some of the guys in the midwest areas are running.
