CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 12-07-2011, 04:30 AM
  #2446
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Originally Posted by RedBullFiXX
Yes there is.
Right HERE
Originally Posted by Still Bill
Nice post Dave.
Very good info on that link! When i first got into pan cars Mark Payne's blog is where i learned to set them up.
nitrobeast is offline
Old 12-07-2011, 04:40 AM
  #2447
Jsaves's Avatar
Default motor change?
When do you guys make a motor change due to age and or performance?
13.5 to different 13.5 or 17.5 to a different 17.5?
What are the things you are looking for in drop off?
Thanks and God Bless
Jsaves is offline
Old 12-07-2011, 07:01 AM
  #2448
nitrobeast's Avatar
Usually they get slower and run a little hotter then normal.
Ive also seen guys think the motor is the problem, but it ended up being the battery that was tired.
Old 12-07-2011, 09:21 AM
  #2449
joeymdz's Avatar
Trader Rating: 13 (100%+)
if that's the case it would be what is the motor of the month
nitro is spot on... also you may want to clean that motor. i did that to my old DUO and now that thing is awesome.... except.... i just picked up a revtech and yeah.... no hype.. thats just a great motor! (shameless plug )
joeymdz is offline
Old 12-07-2011, 11:16 AM
  #2450
eevul's Avatar
I originally bought a used CRC gen X10 and upgraded it to the LE. I also changed the front kingpins to the 1/12 ones and I am running the .55 springs. I feel that I can push this car to the limit and not have to worry about it. I did test drive the X-Ray WGT cars before going with CRC and now I know that I have made the right choice. I absolutely love this car and wonder how much better it will be if I upgrade the front to the lay down type servos. Does it really make that much of a difference?
eevul is offline
Old 12-07-2011, 11:31 AM
  #2451
Can someone enlighten me on what rollout should I run with 8.5T Brushless, 2s Lipo please ?
Backspace. is offline
Old 12-07-2011, 12:09 PM
  #2452
al dente's Avatar
I would love to help you, but we do not run mod wgt here in the states. especially with 2s.
al dente is offline
Old 12-07-2011, 12:27 PM
  #2453
el salvador's Avatar
Depending on your Tracks limitations ,ie, how much corner speed your track would allow, (tight/technical or open/flowing) and what level of "HorsePower" the rules at your track permit, the 17403 offers 200mm front track width and with the servo mounted forward allows the battery to be moved further forward. The change in weight distrubition along with the lower COG will allow more corner speed with reduced tendancy to "Traction Roll".
The 17402 is the standard/narrow track width suspension mount. Everything is a compromise as in the trade off between the Flat vs Angled servo mount in terms of steering response. I like the new option parts CRC now offers however, I've found the plastic servo brackets CRC sells to go with the CF suspension plates to be lacking of integrity, therefore I've opted for some Xray alloy TC servo mounts instead.
el salvador is offline
Old 12-07-2011, 12:34 PM
  #2454
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Have you drove Korage Xray ??
OVA is offline
Old 12-07-2011, 03:41 PM
  #2455
joeymdz's Avatar
never heard of that car.. but i have heard that Xray cars were made for the "bashers"
i thought this was the CRC thread?
MARIO... you still racing? lol
joeymdz is offline
Old 12-07-2011, 05:02 PM
  #2456
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Hey mdz, correct me if i'm wrong, but don't you run on a 'short course' carpet track?
Drillit is offline
Old 12-07-2011, 07:52 PM
  #2457
joeymdz's Avatar
I run my crc on a carpet track that is shared with sct's on foams.. Was that what you needed to hear? Im sure that your xray basher could work on "our" home track but then again.. xray doesn't have any customer support for their wgt .. Its a basher
joeymdz is offline
Old 12-07-2011, 11:52 PM
  #2458
Pablo Diablo's Avatar
I run my 6.5 on a 1/8th track at 42mm with a reasonable amount of ESC timing advance. I guess with a 8.5turn around 45 - 50mm depending on ESC type and settings.
Pablo Diablo is offline
Old 12-08-2011, 01:48 AM
  #2459
Drillit's Avatar
Drillit is offline
Old 12-08-2011, 04:30 AM
  #2460
nitrobeast's Avatar
Yes, laying the servo down makes a huge difference...Before this part was available from CRC i layed my servo flat in the same spot and it was .2 faster
The fact that you can move the battery forward by flipping the servo only sounds like it will work better. I ordered the parts needed and hope i can run it this weekend.
