Hot Bodies TCXX
#1441
2 PM's sent about MyLaps Personal Transponder, just waiting on the response! Thanks! Richard
#1442
Any other manufacturers outdrives compatible with the HB spool? I'm looking for outdrives that allow for the use of blades.
#1444
nope the POM and steel spool outdrives are perfect fit with the 2mm axle pins up front. You can run the HB gear diff up front if you want to use blades also.
On my older TCX I was using Spec R gear diffs with blades, and I can use the ver.1 hb dcj that had bigger axle pins.
#1445
What's the difference between the Ver.1 and Ver.2 DCJ? I thought it was just the pin size that was different. Price for the Ver.2 is $45 each!!!
#1447
#1449
I've never seen DCJs from any manufacturer to be rebuild able. I believe the difference are in the pin size. I have the old ones and I beleive I spent around $30 each which I already thought was pricey...
#1450
The tamiya dcj's I'm using are rebuildable. There are clips that hold the pins in.
In looking at my hb shafts in the other car, it appears they are Not rebuildable like I was told. I really never looked at them closely.
So, I would purchase more tamiya shafts or the rsd shafts from reflex racing.
#1451
#1452
where can i get a steering rack for my tcxx
ever since i build my tcxx i been having problems out of the steering rack i had to replace the +2arms the bearing were not in it from the kit towerhobbies replace them i feel like i got a bad kit i want to continue running my tcxx im getting second thoughs my hotbodies tc with the exotek chassis more consistent than my tcxx so in other word where can i get a steering rack
#1453
#1454
first it was the arms now the steering rack lost the bearing i ran the car sunday spoiled my whole day i build the kit 2month ago ever since i could not get the screw stay in on the bottom of the rack so fred told me to put blue lock tight on them it stayed and now this
#1455
A-Main has HBS68824 Hot Bodies +2mm Steering Arm Set -in stock-
This is the rack that comes with the TCXX.
