Like Tree7Likes
Hot Bodies TCXX
Old 08-12-2013, 01:14 AM
  #1291
Korey Harbke's Avatar
Originally Posted by goots
Does anyone have a starting setup for the upcoming IIC. It will be my first time attending and racing in the 17.5 TC class. Also, I have no experience on carpet as I race mosty on juiced asphalt. So looking for a setup I could easilly transition to for the rug
Give this a try. Oliver was very successful with it, so It's worth a shot.
http://www.petitrc.com/reglages/hotb...ett2013042728/
-Korey
Korey Harbke is offline
Old 08-12-2013, 01:56 AM
  #1292
Trader Rating: 20 (100%+)
-Korey
very interesting sheet. Almost look like an asphalt setup.
goots is offline
Old 08-12-2013, 03:31 AM
  #1293
MUGEN_MAN_666's Avatar
do you have a picture of the breakage? I assume you had an impact or crash when it happened.
For more durability Im sure you can run the 2mm pin aluminum dog bones, pro 4 steel dogbones, or any 44mm HB dogbones with the appropriate diff blades for the outdrives.
na sorry goots I don't have any pictures of them and no there was no crash or impact involved in them breaking.
MUGEN_MAN_666 is offline
Old 08-12-2013, 11:50 PM
  #1294
I know the rest of the team has been running short links and lower roll centers just about everywhere, but I still haven't been able to get it to be all that great on high bite carpet for some reason. When I reverted back to an old school type of setup, the car was smoother and managed traction roll a lot better. This setup reminds me of that.
The Yokomo springs were really good on carpet. The main thing I noticed you run significantly less droop with them to keep any wild weight transfer in check.
This is just what I experienced though. Unfortunately, I never found a carpet setup I was totally happy with. Asphalt is a different story. My car has been pretty good so far. I'll give it another crack this upcoming carpet season.
-Korey
Old 08-13-2013, 08:14 PM
  #1295
O.Franke's Avatar
Hello,
my asphalt set up is pretty strange compared to this one.
Nearly all German drivers with the TCXX use kind a similar setup as mine.
I will post later a set up which i used at the warm up race for the German nationals. I will also start with that set up at the Nats next week.
And I finally managed to register in this forum D
best regards
Oliver Franke
O.Franke is offline
Old 08-14-2013, 01:14 AM
  #1296
Nice! Welcome!
Old 08-14-2013, 01:35 AM
  #1297
Airwave's Avatar
Wow! Another great driver! Welcome Oliver!
Airwave is offline
Old 08-14-2013, 07:14 AM
  #1298
Welcome aboard Oliver!
Looking forward for your inputs!
Itchy is offline
Old 08-14-2013, 08:43 AM
  #1299
tc3 racer sc's Avatar
Default Where can I find a floating servo mount
Where can I find a floating servo mount for my tcxx and purple pulley 20 tooth gear at putting a car together for carpet season
tc3 racer sc is offline
Old 08-14-2013, 09:56 AM
  #1300
jag88's Avatar
Here is one I found, http://www.arrowmax-rc.com/index.php...oducts_id=1079, there may be others ...
jag88 is offline
Old 08-15-2013, 09:02 AM
  #1301
mxgregg's Avatar
Trader Rating: 32 (100%+)
The Purple pulley parts are off the TCX. Search Amain hobbies or Tower Hobbies.
mxgregg is offline
Old 08-15-2013, 09:19 AM
  #1302
Fred Hubbard's Avatar
Beware 68273 listed at Tower as being purple isn't purple.
Fred Hubbard is offline
Old 08-15-2013, 10:50 AM
  #1303
mxgregg's Avatar
You need 68705/68706 & 68727.
http://www.amainhobbies.com/advanced...ds=tcx&x=6&y=8
mxgregg is offline
Old 08-15-2013, 05:25 PM
  #1304
Thxsz
Old 08-15-2013, 05:54 PM
  #1305
bukil's Avatar
Trader Rating: 39 (100%+)
This is a good alternative for pulleys. You get both for ~$20 only!
bukil is offline
