Losi 8ight building and setup >
Old 10-02-2006, 10:50 AM
  #181
speedy2's Avatar
kyosho clutch does work right on
just use the shimm coming with the 8ight behind the flywheel, rest kyosho stuff 13 /14 T bells to..
mugen works and jammin too with the losi bell, just have to adjust with the shimming
speedy2 is offline
Old 10-02-2006, 04:41 PM
  #182
can people post more pics of their 8ights please!
SPZA is offline
Old 10-02-2006, 04:49 PM
  #183
Flode007's Avatar
Her is mine Losi 8ight .
Flode007 is offline
Old 10-02-2006, 05:51 PM
  #184
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
Mine again
Attached Thumbnails Losi 8ight building and setup-losi8-001.jpg   Losi 8ight building and setup-losi8-002.jpg   Losi 8ight building and setup-losi8-003.jpg
SCUBA STEVE is offline
Old 10-02-2006, 05:52 PM
  #185
Also wanted to tell everyone I'm going to try the fioroni clutch tommorow..I'll let you guys know how that goes
Old 10-02-2006, 06:00 PM
  #186
rdeppen's Avatar
Which Fironi Steve?? The Turbo Slider??
rdeppen is offline
Old 10-02-2006, 06:51 PM
  #187
Panther's Avatar
Here's my 8ight.........
Panther is offline
Old 10-02-2006, 07:09 PM
  #188
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
Yeah that looks great. I take it that you are the one making those skins? I was just checking out that site for the first time.
Stewart Fan is offline
Old 10-02-2006, 07:14 PM
  #189
1 Xtreme R/C's Avatar
Trader Rating: 17 (100%+)
Just got mine done last night and broke the engine in. Gonna hit the track tomorow for some test runs.
Novarossi plus 21-5
9886 pipe, short header
Futaba 9351's throtle and steering
HT Batteries 1500mAh LIPO reciver pack and voltage regulator
Spektrum reciver
Proline wing
I'm also using a OFNA universal starter box, the narrow black one with twin motors. After you turn the starter wheel assmbly 90 degrees to fit an 1/8 scale it lines up nicely with the 8ight chassis. I shaved the wheel down a little and it works realy nice. It has a smaller diamater wheel than the boxes with the single big 12V motor, so it fits the small slot for the 8ights flywheel better.
I also was a little leary of the clunk in the fuel tank being able to pick up the last bit of fuel. On the last tank of break in, I wasn't watching and ran it out of fuel. When I opened the lid all I saw was fumes! It got every last drop out of that tank. Just make sure the clunk flops around freely and it should work great.
1 Xtreme R/C is offline
Old 10-02-2006, 11:24 PM
  #190
JBRacing's Avatar
Here is mine:
JBRacing is offline
Old 10-03-2006, 03:53 AM
  #191
rdeppen, Yes, I'm going to try the turbo slider ......hopefully it will work on the 8 .... I'm sure it will as long as the 8 clutch bell rides over it correctly....I'll keep ya posted
Old 10-03-2006, 05:50 AM
  #192
Has anyone ran this on a loose track yet? The ones I have seen can't seem to get the rear to settle down. Anyone else having that problem?
*Topher* is offline
Old 10-03-2006, 06:15 AM
  #193
rdeppen's Avatar
Yes most are. Some are saying the CVD's need to break in. I don't buy that one myself. A better theory would be the kit comes stock with a 14 tooth bell and an aggressive clutch setup. I'm leaning towards softening the punch with a different clutch spring setup and also going to a 13 tooth clutch. Should really help with wheelspin IMO
rdeppen is offline
Old 10-03-2006, 07:06 AM
  #194
Davidka's Avatar
Trader Rating: 86 (100%+)
I think that it's more that nobody has developed a different setup yet. They all are using the Travis/Drake setup and there are plenty of things that can be changed about that setup to quiet down the rear end. While I don't buy the CVD thing I can see the diffs needing a few tanks to settle in. My seals are pretty tight and the 7k oil in the middle diff feels like 10k right now. Much heavier feel than the 7k I am running in my Mugen.
Davidka is offline
Old 10-03-2006, 07:08 AM
  #195
R40Victim's Avatar
Mine came with two full sets of clutch springs, but only one set is mentioned in the instructions. Does anyone know wich are heavier/stiffer?
R40Victim is offline
