Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 08-29-2006, 01:30 PM
  #15886
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I would guess that you're severely under geared. However, not having raced stock in years, I'm not 100% sure what the current motors are geared at. But I know with most 19 turn motors, we're in the low to mid 6's and you're at 7.46. Under gearing a motor can be just as, if not harder on it than over gearing.
Jon Kerr is offline
Old 08-29-2006, 01:36 PM
  #15887
heavy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Rookie Solara
Yeah, just joined Nexus and most of the Hurricane peep with a Mi2EC, one hell of a solid car.....and ran couple minutes around and start smelling motor is burning....temp it, just a little 197 degree F...
Used 28/116 with Takeoff 27 rubber....and wondering am I under or over gearing...? My motor is a fairly new Binary/Epic Roar stock (old style but rarely used before).
One thing Nexus kinda gave me an idea it is UNDER....the car is very flat after 1/4 of throttle, already MAX out with like 30%-40% of throttle, that might cause the overheat....or the motor is so under that it rev like crazy..
Any idea would be greatly appreciated.........I love this EC.
Try a 32 tooth pinion - won't be far off unless it's a tiny track.
heavy is offline
Old 08-29-2006, 01:37 PM
  #15888
Originally Posted by Kevin K
Howard....what track were you running on? That gearing looks close to the tracks around here. Thats what I have used with a monster before. If your motor was really hot maybe there was something in the motor or something else going on I dont think it was the ratio.
Thanks Kevin, I hope I don't have to wait untill the MWAS race and have you to figure that out for me.............yes, I was using your suggested gear ratio and I am sure it is something else.....like I mentioned before, it might be my motor, but that motor, I think when it was new, I ran like no more then 2 5 minutes run and thats all....of course, what the heck I know about electric motor, I can do any kind of centax clutch and nitro engine, electric motor, not 1 single clue..
Thanks Jon and Heavy......I think I am heading to the right direction, I just need to go to the "real" track and test the running........I am more toward "UNDER" because my car launch like a rocket but top out very quick (from the stock motor standpoint)........Heavy, the track I am running is very tight - because that was my basement for some quick test running. (sorry to confuse everyone).
I've also ran my foam car w/monster stock in the basement....for about 3 packs of batteries, motor temp are about normal....
Solara is offline
Old 08-29-2006, 01:45 PM
  #15889
Trader Rating: 42 (100%+)
We'll get it straightened out.
Maybe some of you saw the famous RSR Raceway on the internet LOL The marshalls are Kamikaze style!
http://video.google.com/videoplay?do...5&q=xmod&hl=en
Nexus is offline
  #15890
Kevin K's Avatar
Trader Rating: 32 (100%+)
Ok wait until you get to the real track to figure out gearing.... When you are at His and Hers on saturday(if you are going) the 28/116 would be ok...thats what I ran there with stock....if anything I would drop a tooth.
Kevin K is offline
Old 08-29-2006, 02:13 PM
  #15891
Thanks KK...too bad you won't be there this weekend....and I will keep the 28/116 for now. I am not sure running electric motor 200 degrees indoor over carpet will do any harm for anyone, I ran my nitro engine as high as 300 degrees.........I think they are the same
Solara is offline
Old 08-29-2006, 10:42 PM
  #15892
any mi2 ec tips? looks more andmore like i could be upgrading so might get some tips?
aus jd 2703 is offline
Old 08-30-2006, 07:34 AM
  #15893
Jon Kerr's Avatar
There's really nothing you need to do to the car. Just make sure it's tweaked straight and the setup is proper (just like any car) and you'll be very happy with it.
Jon Kerr is offline
Old 08-30-2006, 08:22 AM
  #15894
PW
PW's Avatar
Make sure you only use 1 diff shim per diff and the suspension mounts are mounted properly (hinge-pin in the high position).
PW is offline
Old 08-30-2006, 08:38 AM
  #15895
Jon Kerr's Avatar
Forgot about that.
Jon Kerr is offline
Old 08-30-2006, 08:57 AM
  #15896
seaball's Avatar
the car is awesome on all surfaces out of the box. i would advise you get some heavier front axles/cvds and a p-dub bumper to keep durability high, but the car is hella fast out of the box.
seaball is offline
Old 08-31-2006, 10:18 AM
  #15897
New Featured Driver coming soon on Pitspace
(not wearing a dress )
Nexus is offline
Old 08-31-2006, 12:00 PM
  #15898
IslandBwoy's Avatar
Talking
wtf is he looking at. I've always wondered.
IslandBwoy is offline
Old 08-31-2006, 12:26 PM
  #15899
Jon Kerr's Avatar
He's trying to do his super model pose.
Jon Kerr is offline
Old 08-31-2006, 01:50 PM
  #15900
STLNLST's Avatar
He sort of has that Derek Zoolander look on his face.....
STLNLST is offline
