JConcepts Thread
#3091
Thanx for that guys. Decided on the airtronics 94362z.
Torque: 100 oz/in @ 4.8V, 125oz/in @ 6.0V
Transit Time: 0.09 sec/60 degrees @ 4.8V, 0.07 sec/60 degrees @ 6.0V
Weight: 2.11oz (59.8g)
Dimensions: 1.54" x 0.79" x 1.47" (39 x 20 x 37mm)
#3092
DG Designs - where or how can i get quick change front axles like that????
#3093
Send this guy a PM http://www.rctech.net/forum/members/...n-kellogg.html I am not sure how he does it but it uses Associated parts.
I just used XXXcr front spindles and ground them down. I need to make a ver 2.0 because i did have the correct drill bit and i have a little more slop than i want.
#3095
any plan of having the goose bumps for rear tire to match the frt 4wd~~~
http://www3.towerhobbies.com/cgi-bin...&I=LXUFB0&P=SM
#3096
Other than than 2 pairs of sc goose bumps, what rims (part #) do I need? Is there better foam I can put in there?
#3097
http://www.jconcepts.net/store/index...dex&cPath=4_36
#3098
I have a slash.
#3099
do u guys make Rulux rims for standard T4 rears?
Not the Quick change ones.
#3100
[QUOTE=PW;6247797]That is on the list
Glad to here that you have a 1/16th slash body on your list. Put me down for one when released. Is the Mini Inferno body discontinued? I don't see it on the website anymore. It fits the Mini Revo/Slash body and wheelbase you just have to create custom mounts. I have a half 8 buggy built from a 1/16the Slash and would love to get the Jconcepts high flow body. I have one of the other guys bodies on it today just to finish the model today.
Now I just needs some Goosebumps for the 16th Slash and I'm set!!!!
#3101
#3102
Metric BJ4?
Haven't seen it asked before, but has anyone done a metric screw conversion to their BJ4? I'm only considering doing this to all the screws going into the gearboxes, since it seems like the SAE screws strip the plastic pretty easily, and would like some input as to how much modification was necessary to get the countersunk screws sitting flush before I start drilling the carbon and aluminum bits
#3103
#3104
sooo when do the 7s come out for 2wheel drive buggy?
#3105
