Like Tree86Likes
Hpi Pro 4
Old 03-31-2005, 06:02 PM
  #10666
axel's Avatar
Yeah my car has flipped over do to bumps by other cars, i've hit boards head on. But if i get hit at low speeds during a turn then it starts clicking.
axel is offline
  #10667
axel's Avatar
axel is offline
Old 03-31-2005, 06:16 PM
  #10668
moot's Avatar
i will be running my pro4 in the 540 'sliver can' class on the weekend,what sort of gearing do you guys reckon? should i keep it the same as the 27t class?
moot is offline
Old 03-31-2005, 10:22 PM
  #10669
Moot ....Na Stock gearing is to low...On a fast flowing track guys at our track run up to 50mm rollout.
Barger is offline
Old 04-01-2005, 12:20 AM
  #10670
Vance's Avatar
Moot : For a normal Tamiya type 540 2xvent Johnson motor, I used from 47-51mm rollout ... depending on track. Using 60T(48P) spur & from 36T-40T(48P) on Jaco Nitro Shoes foams. Further 60wt-front&50wt-rear oil with AE red-front&AE gold-rear springs. Remember that especially with stock your drive-train has to be 200% effiecient as every little part has an influence. If you are looking at hop-ups, definitely consider the Square TI input shafts; carbon drive shaft; ceramic bearings (I like ACER). Use a piece of car shammy with the vent holes cut open and keep it wet before going on the track(I use a mediacal syringe with water). This is cheap, ligther than a heatsink and even try Nitro Freeze spray to keep it really cool. Also change you pivot blocks from the stock set to 0deg-front & 1deg-rear.
Hope it helps!
Vance
Vance is offline
Old 04-01-2005, 07:39 AM
  #10671
Mach10_shooter's Avatar
Trader Rating: 40 (100%+)
Originally posted by Mach10_shooter
I thought there might be more interest in this. Anyone else?
Chris
Here is a battery strap I've come up with. Is anyone interested?
Mach10_shooter is offline
Old 04-01-2005, 07:41 AM
  #10672
Skill's Avatar
Wow that looks really good
Skill is offline
Old 04-01-2005, 07:50 AM
  #10673
Mach10_shooter:
Have you seen the Schumacher carbon battery-straps?
They look quite similar to your design, with a vertically mounted piece along the strap, with the shape of the battry-cells macined. If you can see what i'm trying to explain.
Erlend is offline
Old 04-01-2005, 07:55 AM
  #10674
Thank you, I am also working on a bumper brace, camber link mounting plate made from 3.1mm material, and a custom front sway bar mount that mirrors the sway bar mount over on top of the upper deck...
Old 04-01-2005, 07:56 AM
  #10675
Originally posted by Erlend
Mach10_shooter:
Is the vertically mounted piece glued onto the other or is it one piece machined?
Old 04-01-2005, 08:37 AM
  #10676
jt6
jt6's Avatar
Looks good. I am interested in one too!!
jt6 is offline
Old 04-01-2005, 09:01 AM
  #10677
Default Bumper brace
Here's my bumper brace.
Old 04-01-2005, 09:02 AM
  #10678
Thraex's Avatar
What's wrong with strapping tape?!
Thraex is offline
Old 04-01-2005, 09:26 AM
  #10679
jt6
jt6's Avatar
Default Re: Bumper brace
When will these be available?
jt6 is offline
Old 04-01-2005, 09:33 AM
  #10680
Trader Rating: 17 (100%+)
How Much would the Bumper brace cost???
EngTat is offline
