Tamiya F103 Forum
#183
Ho try this GPM parts on his F103RS
Has any one try any of this parts from GPM on his F103RS.
#184
What ESC is good for my F1
What is a good ESC for my F103RS F1 chassis i now have a Kopropo but i think its not the best choise because you can setup braking, i love LRP ihave a V6 in my Axis2 and its the best. Can antbody help me.
#185
What kind of Nicd is the best for the F103RS
Now i have Sanyo 1700. What is a good choise for a direct drive. But i drive whit the Acto Power F1 motor.
#186
What kind of gearing can i yous in my F103
What kind of gearing is the best for a large Parking lot whit a lot of straits. I drive whit Acto power F1 motors and a 0,4: 104 or 89 spur and the original spur from the kit.
What kind of pinions can i thake the best.
I have these motor pinions: 0,4:20,21,22,23,25,28 0.6:14,17,18,21,23,24
#187
Those GPM looks cool. as for batteries are you getting the run time you want with the 1700? If so stick with it or if not go with 2400. If you want even more performance try matched but for me matched is not worth it in stick packs.
Well if you want the best esc get the LRP Quantum it small and can handle mods or the V7.1, or the Novak TC2
#188
Regional Moderator
jcr: Man, can a V7.1 fit in a F1 chassis?
rimaracing: Quantum is a good choice. Also the GMV12 and Novak Atom.
Oh, and don't forget the new KoPropo speedo, it has programmable everything on it.(as long as you buy the programmer, just like the Novak Atom) And then theres the Keyence A-01 series and the new ZeroVExtreme.
All of these are programmable very small speedos, so you have plenty of choices.
And you can't go wrong with any of these.
#189
well it should fit. when i had my F103, I was using a Duratrax Streak and it was bigger than the LRP V7.1 so it will fit.
Or you can always stick with micro stuff like micro receiver and esc like the quantum and atom. but it all depends on how much you want to spend
#190
rimaracing
That GPM stuff looks cool, but it must weigh a ton! I'd rather have a light car than a bunch of eye candy, personally. As far as ESC's go, I like LRP Quantum Sport because it's really small, lightweight and pretty cheap. They also have an on/off switch. I just bought a V.4 which is nice, but no on/off switch!
The gearing is you run is determined by a few factors. I usually race on a fairly small track. It's very yechnical, but has a lot of straights that aren't very long. I don't really need a lot of top end speed, but I do need a lot of acceleration. I usually try to run around 5.36:1 up to 6.00:1 gear ratio. The only combination you have that is in that range is your 109T spur and your 20T pinion. That would put you at 5.45:1. You might want to switch to 48 or 64 pitch gears where you'll have a lot more choices of gears. I run Kimbrough 75T, 48 pitch spurgears on my cars and have a bunch on pinions that I change depending on the track. Going to higher gear ratio will also give you more run time, so if you run enduro events, this may help you out. My races are 6 minutes, so it's not such a big deal for me.
#193
Originally posted by jcr
...when i had my F103...
#195
didn't i tell you that i had one some time bad, like when you're getting started.
