NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 11-14-2011, 03:50 AM
  #6916
COBRARACING's Avatar
Originally Posted by venom54
We can assist with the cap board.
http://www.rabhobbies.com.au/estore/...cturers_id=226
Cheers
Ren
thanks ren
COBRARACING is offline
Old 11-14-2011, 03:56 AM
  #6917
Originally Posted by Born2Run
I ran my 5.5T as well my 8.5T with the 930 stock this time with lipo protection on 3.0v/cell and after a couple of minutes the voltage protection kicks again.Batteries are Gens Ace 5000mAh 50C and i have run them only a few times.The only way to go is to disable the voltage protection but it's too risky.A couple of guys with the SP speedo (with the SP 323stock s/w) but SP 4.5T motors and more agressive settings don't have this issue.I'm not sure why this happens but for sure the new 930 s/w didn't help.
What is your punch level ? Are the batteries really 50C ? you will never know have you tried other batteries ?If your telling me that it will run with no voltage protection but when running the protection mode it cuts in after a few minutes it seems your battery is dumping very quickly doesnt seem to hold a linear discharge .
Old 11-14-2011, 03:59 AM
  #6918
M7H
M7H's Avatar
No,no.Speedo is the HW 120 v2.1 Bullistorm was only the 5.5T motor.
Last weekend during the EPS at the MACH track, there was somebody with a HW extreme ESC also having a similar issue, after I gave him a new sensor cable, it solved the problem as far as I know....
It can be a bad contact in any of those small pins, who knows....
M7H is offline
Old 11-14-2011, 04:00 AM
  #6919
M7H
M7H's Avatar
Can also be a bad soldering in the ESC/Lipo or ESC/Motor circuit.....
M7H is offline
Old 11-14-2011, 04:01 AM
  #6920
Default Settings
If I've got this right, if I reduce the boost number ie from 30 to 25, does the turbo then come in earlier and therefore the slope etc with it?
scoop is offline
Old 11-14-2011, 04:46 AM
  #6921
Default Blinking led is yellow instead of red in a 1s
Cobra:
I purchased 3 1s units in August. We just put one of them in the no_timing mode and it blinks yellow instead of red. Tech inspection OK'd the unit after checking the software. I just thought I would let you know about this.
Also, a warning to users. If you move the neutral point on your transmitter a click or two the ESC may not blink to the satisfaction of tech. If you encounter this problem first try the transmitter trim (up or down) to get the proper spot for the slow blink. If you are trimmed to the brake side it will be solid red, I am not sure about the forward side as I haven't tried that adjustment.
old_dude is offline
Old 11-14-2011, 05:39 AM
  #6922
Born2Run's Avatar
Sensor cable was my first thought so i tried 3 different cables and i had the same issue.It's very strange because i have the same problem on both cars with 2 different speedos (HW 120 v2.1 both).Another thought is that my batteries aren't so good so with all these turbo and booster settings, voltage is dropping too fast hence the lipo protection kicks after a while.Next Sunday i'll try with the same settings but with new and bigger capacity batteries and i hope i'll get more luck.
Born2Run is offline
Old 11-14-2011, 05:46 AM
  #6923
Born2Run's Avatar
Punch level was 2.As you're said i suspect the batteries are dumping very quickly.They don't seems they are 50C
Born2Run is offline
Old 11-14-2011, 09:02 AM
  #6924
Check your soldering is good and the plugs you are using are clean and decent quality as any of this can give high voltage drops and cause the protection to kick in. Easiest way to test things would to be use a mates pack and see what happens. lipo C rating i wouldn't worry about too much as even the weakest of lipos should cope fine. I know you say you're running 5.5t but there are only so many amps you can put down before the wheels start spinning.
YZFAndy is offline
Old 11-14-2011, 11:28 AM
  #6925
mingnon's Avatar
Trader Rating: 12 (100%+)
Cheers
Ren
Thanks Cobra and Ren :-)
Ren have placed order
cheers
mingnon is offline
Old 11-14-2011, 02:31 PM
  #6926
Your battery could be faulty, but a Gens Ace look like one of the few that can pretend being true C.
Did you try to change the firwmare of the ESC, then load the firmware you are using again ? It can fix some bugs.
FFred is offline
Old 11-14-2011, 02:53 PM
  #6927
How does the lrp x12 go with the hw xtreme? Particularly curious with the 13.5, have heard mixed reviews.
What software works best with them?
Mb3195 is offline
Old 11-14-2011, 03:00 PM
  #6928
Trader Rating: 64 (100%+)
Im planning on running my justtock in a 12th scale. Im going to run a tq booster. Do i run with the esc switch on or off?
MC112b is offline
Old 11-14-2011, 03:20 PM
  #6929
We run older 224 with 10.5t boosted so it stays cooler, my guess is that it should be the same for 13.5t
olly986 is offline
Old 11-14-2011, 04:36 PM
  #6930
Trader Rating: 22 (100%+)
I have tried this combo with 930 and it is very fast just unreliable.
When I was griding up and came to a stop with brakes on the car would go backwards once I pulled the throttle!
Reverse was not set!!
If you got spun around and rolled backwards the speedy would go to sensorless!
I tried all variable's of timming on the speeedy and motor to no avail...
The hobbywing claim is that the signal from the X12's is not strong so as the speedy cannot pickup where it is in relation to sensor position.
Cobra Racing did say he would look into it further in a post I submitted weeks ago... Still nothing.
bjspinner is offline
