LeMans LMP1: 200mm Pan Class Discussion >
Old 01-26-2014, 04:56 PM
  #271
wwddww34's Avatar
Trader Rating: 9 (91%+)
Would an old Tamiya F103RS chassis with a Toyota TS020 body (non-wedge tail) and a set of Pit Shimizu 0544 fronts and 0542 rear tires mounted on F103 rims meet USLMP Specs?
wwddww34 is offline
Old 01-26-2014, 06:26 PM
  #272
nrtv20's Avatar
The preferred tire is speed passion lm1 foams. Run whatever your club allows but tires are still a work in progress.
nrtv20 is offline
Old 01-27-2014, 06:19 AM
  #273
howardcano's Avatar
Trader Rating: 37 (100%+)
Sounds fine to me! Just double-check dimensions and weight.
howardcano is offline
Old 01-27-2014, 08:15 AM
  #274
Rick Vessell's Avatar
Yes. As long as it fits the dimensions you're good to go. My WGT conversion uses the 103 wheels/tires also.
Rick Vessell is offline
Old 01-27-2014, 11:38 AM
  #275
wwddww34's Avatar
Cool! Thanks for your responses.
wwddww34 is offline
Old 01-30-2014, 06:51 AM
  #276
liljohn1064's Avatar
Trader Rating: 17 (100%+)
We had an F103 with a Toyota body at our last event. He was running the softest tires and a 17.5 and did not win against an LM-1 with a 21.5. The SP foams have great grip and last through the whole run. This LM-1 is the real deal.
liljohn1064 is offline
Old 01-30-2014, 10:42 AM
  #277
trackdesigner71's Avatar
I saw the video, you guys pick up any more LM1 runners since then?
I have a feeling youll see more rubber tire runners once the outdoor season gets going in earnest come March or April
trackdesigner71 is offline
Old 02-15-2014, 03:21 PM
  #278
This class is still very popular locally. We are mostly LM1 at the moment. Still waiting for more to jump on the bandwagon. Foam tires are not an issue. The paint schemes are incredible.
FYI, the serpent F110 rear axle is standard and will fit any WGT. The diff and left side wheel adapter are 14 mm.
Old 02-16-2014, 02:52 AM
  #279
howardcano's Avatar
Default Mounting Speed Passion LM1 Front Tires and Wheels to a WGT Chassis
Here are several ways to mount Speed Passion LM1 front tires/wheels, #SP000990, on the front of a WGT or 1/10 scale pan car. Choose whatever method you prefer, or whatever method uses the parts you already have in the parts box!
The first method is pretty low-tech and quite obvious, but works okay. You'll need four unflanged bearings with 3/8" OD. The ID should be whatever fits the axles on your car, 1/8" or 3/16". You'll also need some brass shim stock, 0.010" thick. (I used K&S #5251.) The 3/16" ID bearings are thinner than the 1/8" ID bearings, so if you use these, insert one 6mm ID x 10mm OD washer, about 0.5mm to 0.8mm thick (Duratrax #DTXC9767), into each opening in the wheel before inserting the bearings to take up the extra space.
Cut the brass shim stock 1/8" wide and about 1.15" long (good scissors work nicely for this). Form the shim around the bearing OD, then insert the shim (after the washer, if necessary) into the wheel. Then use a round, flat-faced tool to press the bearing into place. The tool should bear against the outer race of the bearing. I used a socket wrench.
When inserting the shim in the wheel on the side opposite one that has the bearing already inserted, line up the gap in the shim to the same place as the first to reduce the possibility of wobble. (The rims wobble enough as is!)
After doing all four bearings, mount the wheels to the car in the usual manner.
The SP wheels will give an extra 1.5mm offset per side, or a width increase of 3mm across the car, compared to BSR WGT tires.
Sources:
Bearings, 1/8" ID x 3/8" OD x 5/32" Width:
http://www.avidrc.com/product/1/bear...-bearings.html
OR
Bearings, 3/16" ID x 3/8" OD x 1/8" Width:
http://www.avidrc.com/product/9/stan...-bearings.html
and Washers, 6mm ID x 10mm OD:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLGJ1&P=7
Shim Stock:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSU64&P=7
Here is a more elegant way to mount the wheels on 1/8" axles:
You'll need four bearings, 5mm ID x 10mm OD by 4mm Width. These will need a reducer to match the ID to the axle. I used a nylon spacer, 3.2mm ID x 5mm OD x 11mm long (Harwin R30-6701194).
Place the spacer inside the wheel, with a bearing on each side. Now use a long 4-40 screw, nut, and washer placed through the bearings and spacer to press the assembly together inside the wheel. The washer goes under the head of the screw to press against the inner race of the bearing. The nut presses against the inner race of the other bearing. (Use a washer here, too, if the nut is too small.) Tighten the screw and nut to press the assembly together inside the wheel. The bearing edges should line up with the ends of the spacer when finished.
Place a 4-40 washer, about 0.13" ID x .26" OD x 0.020" thick, onto the axle, slide the wheel assembly onto the axle, place another washer on the axle, then install the axle nut. Don't over-torque the nut, or the spacer will compress and bind things up. Just snug will do. The washers provide a surface for the bearing inner races to contact.
Sources:
Bearings, 5mm ID x 10mm OD by 4mm Width:
Nylon Spacer, 3.2mm ID x 5mm OD x 11mm long:
http://www.mouser.com/ProductDetail/...ACkq%2fw%3d%3d
And finally, the prettiest way to do it! This is just a variation on the previous method, but the standoff is aluminum, which makes it a bit more rugged. The 1/8" axle stubs in the car should be secured with a nut on both ends, since the wheel nut will need to be torqued down firmly to take up the small amount of play between the standoff and the axle.
The bearings must have a 6mm ID, and these types are narrower than the 5mm ID bearings used in the previous example. Place two 6mm ID x 10mm OD x 0.5mm thick washers (Duratrax #DTXC9767) inside each side of the wheel to take up the extra space before installing the bearings. I found that I had to open up the ID of the washers a bit (using a round file or reamer) to keep them from dragging on the standoff.
As in the previous example, two washers are needed on the axle for the bearing inner races to contact, but the washers need a larger OD since the bearing ID is larger. I used 3.2mm ID x 8mm OD x 0.5mm thick washers (Thunder Tiger #PD1966).
Sources:
Bearings, 6mm ID x 10mm OD by 3mm Width:
http://www.avidrc.com/product/8/metr...-bearings.html
Aluminum Spacer, 3.2mm ID x 6mm OD x 11mm long:
http://www.mouser.com/ProductDetail/...mdEbMOHQ%3d%3d
Washers, 3.2mm ID x 8mm OD x 0.5mm thick:
http://www3.towerhobbies.com/cgi-bin...?&I=LXARFH&P=7
Old 02-16-2014, 03:16 PM
  #280
Ed Delgado's Avatar
The only thing I would do differently in your case is run a set of Speed passion LM wheels instead of the F103 wheels.
Ed Delgado is offline
Old 02-26-2014, 11:36 AM
  #281
Anyone try to convert a Serpent S100 to LMS spec? From the looks of it, it needs the F110 rear right outer diff half and left drive hub and the front needs the F110 front axles. The rear axle has same size bearings, but has a different part number (I'm guessing F110 is steel, S100 are aluminum and carbon)
Old 02-26-2014, 03:15 PM
  #282
Ed Delgado's Avatar
Just curious, what is the wheelbase of your Serpent S100?
Old 02-26-2014, 05:23 PM
  #283
I don't have one, but I've seen them online new even though they're discontinued. Stormer has a couple in stock. They are a 200 mm WGT chassis and the F110 appears to be based off that car. Wheelbase is 260, like the CRC.
Old 03-04-2014, 04:28 PM
  #284
nrtv20's Avatar
Just something that popped in my head... if there ever was a RC LeMans race you could have one of the classes be Porsche GT3, run them as VTA rules with any Porsche body, VTA tires and all. Classes could be LM-1's, WGT, USTG and the Porsche GT3 class.
Maybe spec the WGT body to a Daytona prototype? Now that would be a cool looking race series.
nrtv20 is offline
Old 03-05-2014, 08:43 PM
  #285
Really?
I didn't know that.
RoyU is offline
