Like Tree26Likes
3 racing new F1
Old 11-18-2011, 09:27 AM
  #766
texastc's Avatar
Originally Posted by lightfoot
The 104 body will fit... The body post holes are in a different spot... and you will need to cut the front side nose differently for the suspension arms to clear... also the FGX chassis slightly protrudes from the shell, but not bad... also looks like the 104 body is a little shorter in length, so depending on how you position the body you will have more or less motor area exposed...
Thanks, getting an FGX tomorrow sans body. Looks like I need to talk to BP about a body and some decals.
texastc is offline
Old 11-18-2011, 11:33 AM
  #767
Oortael's Avatar
Which tires work on the fgx for asphalt racing?
Oortael is offline
Old 11-18-2011, 11:36 AM
  #768
I'm using Shimizu soft all the way around. Very stable
glinx111 is offline
Old 11-19-2011, 06:17 PM
  #769
texastc's Avatar
I got my FGX today. Still in box, on kitchen table, waiting for wife to go to bed. The build will commence sometime after that, depends on how quietly she goes. Also, we raced today, just 3 of us, my F109 standard with an FGX and an F104W. Ill have some video later once it uploads. Just about 3 minutes of F104W vs FGX. FGX stays close to F104W, but only to keep it interesting. He could have walked away at any time. Yours truly had already crashed out with a stripped servo saver screw, so I made myself useful and grabbed some "footage" as we say in the business My F109 was good today, If I was more consistant, I could have probably stayed closer to the FGX. But Racer Robert is an F1 demon, and Im sure he would have found another gear in his FGX and just added laps. Its really not fair, no matter what car, but man it so fun running the F1s. I have 3 now, and I admit, a problem.
texastc is offline
Old 11-19-2011, 06:28 PM
  #770
superspeed's Avatar
good stuff, let's see the video soon
superspeed is offline
Old 11-19-2011, 06:46 PM
  #771
Sydewynder is offline
Old 11-19-2011, 06:53 PM
  #772
texastc's Avatar
Originally Posted by Sydewynder
Lol So what happens when she wakes up to get a drink of water?
Hopefully she ll grab me a Coke, and go back to bed.
texastc is offline
Old 11-19-2011, 09:44 PM
  #773
snoopyrc's Avatar
I know the feeling. Most of my RC homework takes place when the wife is either away or asleep, or just busy with other things.
snoopyrc is offline
Old 11-19-2011, 10:43 PM
  #774
aussierevo's Avatar
Trader Rating: 14 (100%+)
Default what am I missing?
I'm attempting to set-up a speed passion citrix with a 21.5V2.
I've changed the spur gear to a 35T and I'm attempting to attached a 34T pinion, but for the life of me the pinion simply doesn';t have enough room....I'd be lucky to get a 20T on. That, and the fact the motor hit's the post at the end so no room for movement.
how are people getting motor and pinion to fit to give a half decent rollout/fdr.
aussierevo is offline
Old 11-19-2011, 11:27 PM
  #775
lightfoot's Avatar
Your going to have to shave off a portion of the upper deck near the rear left post... Just dremel off from the bottom but not too much so you can still attach from the upper screw into the post... this will allow you more movement with the motor...
lightfoot is offline
Old 11-19-2011, 11:34 PM
  #776
texastc's Avatar
Here is the video I promised.
grrrrrrrrrrrrr how do they do that?
http://youtu.be/6fJIPaZhO6M
texastc is offline
Old 11-20-2011, 12:22 AM
  #777
aussierevo's Avatar
thanks for that....will give that a try.
Old 11-20-2011, 01:26 AM
  #778
JamesHealey's Avatar
that White n Blue (BMW Sauber?) has so much more drive off the corners than the Ferrari.. Is that the FGX or the F104W?
Reminds me of the famous Gilles Villeneuve battle, but obviously not as cool.
JamesHealey is offline
Old 11-20-2011, 06:34 AM
  #779
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
When I was building the front steering knuckles, and was tightening the set screw for the king pin, I wondered why they thought they needed an e-clip in the center of the pin. Yesterday, on it's first couple of laps at the track, I tapped a board, and wondered "Why in the hell did they think they needed an e-clip in the middle of the king pin."
Mac The Knife is offline
Old 11-20-2011, 06:53 AM
  #780
I believe so. And yea the fgx seemed to have much more steering and able to hit the power earlier. It looked like on rails, the 104w on the other hand was all over the place.
kb525 is offline
