Everything you need to know about your Losi Ten SCTe 4x4....
Truck Manual
http://go.redirectingat.com/?id=42X1...%26p%3D8516085
Truck Manual
Type:4WD Short Course Rolling Chassis
Scale: 1/10
Length: 21.34 in (524mm)
Width: 11.65 in (295.8mm)
Wheelbase: 13.15 in (334mm)
Weight: 6.75 lb (3.06 kg) Fully loaded ready to race
Tire Type : Eclipse SCT
Kit/RTR: Rolling Chassis
Shock Type: Aluminum, Coil-over, oil-filled
Body Clear Polycarbonate SCT
Functional mud flaps with Losi logo
Oversized 12mm anodized, threaded shocks
12mm wheel hexes
Secure battery straps
Battery tray accepts multiple types and sizes of packs
Heavy-duty, 4mm tie rods with captured ends
Beadlock-style SCT wheels with rings
Front and rear sway bars included
Eclipse™ Short Course truck tires
Secure radio box to protect the receiver
Simple adjust, aluminum motor mount
Lightweight black anodized aluminum chassis
Needed to Complete
550-sized Brushless System (Motor and ESC)
1/10-scale Steering Servo
2S LiPo Battery Pack and Charger
2-channel Radio System
Polycarbonate Paint
Scale: 1/10
12mm wheel hexes
Needed to Complete
Polycarbonate Paint
550 Motors
Tekin Redline SC4X 4.5-5.5
Novak Ballistic 550 4.5-6.5T
Novak HV 4.5-5.5T
Fantom Fusion 1 & 2 550’s
Speed Passion V10 3.5R-5.5R
Speed Passion V2 5.5R
Team EPIC Monster Horsepower 550
Team Epic 4x4 Short Course Monster Horsepower 4.5t
LRP X12L Short Course Sensored Brushless 550 Motor
Orion Vortex 10 2800kv (best on 3S)
Castle Creations 1415 2400kv
Novak HV 4.5-5.5T
1/8th Scale Motors
Tekin T8 2650 - Requires slight modification to plastic spacer under the motor mount.
540 Motors
Castle Creations 1410 1Y 3800kv 4 Pole
Gearing recommendations with 40T spur (2 Pole motors)
4.5 550's - 13-16T pinion
5.5 550's - 14-18T pinion
6.5 550's ??
Castle/Neu 4 Pole motors
Castle 3800kv - 13-17T pinion
Castle 2400kv - 17-20T pinion
3MM Mod 1 Bore Pinions for CC 1415 & 1410 motors
http://www.amainhobbies.com/advanced...ds=3mm&x=0&y=0
Recommended ESC’s
Viper VTX10R (3S capable)
Tekin RX8 (Using current limiting (90-80%) can help on motor temps)
Mamba Max Pro
Mamba Monster
Novak Kinetics
LRP SPX8
LRP Sphere Comp TC Spec w/fan
Speed Passion Silver Arrow V2
6.5 550's ??
Recommended ESC’s
Mamba Max Pro
Mamba Monster
Novak Kinetics
LRP SPX8
Stock shock oil f/r - 30w from the factory. Stock Diff's come filled with grease. When disassembling the diff housings, be careful when removing the screws. They have been known to be in tight and require a 1/16th sized hex.
Shock Piston sizes:
#1 0.95mm | #2 1.00mm |#3 1.05mm | #4 1.10mm | #5 1.15mm
Diff housing screw size (for people who have stripped the screws and want another option) Four screws - 2.5mm 45 pitch 10mm. HPI has some screws that work part# Z449 , they are M2.5x12mm 2mm longer than stock but the holes are deep enough in the diff housings.
Diff fluid starting points.
Indoor blue groove 5-7-3 (Front/Center/Rear)
Indoor blue groove 5-5-3 (Front/Center/Rear)
Outdoor med bite 3-3-2 (Front/Center/Rear)
Shock Piston sizes:
Lunsford SCTE Titanium Turnbuckle kit
http://www.lunsfordracing.com/mm5/me...egory_Code=NEW
2 - 4mm x 65mm Titanium Turnbuckles (Front Camber)
2 - 4mm x 68mm Titanium Turnbuckles (Steering)
2 - 4mm x 70mm Titanium Turnbuckles-Long Thread (Rear Camber)
Bearing sizes for the entire truck
LOSA6907 5 x 8 x 2.5 Ball Bearing 4each Steering
LOSA6947 5mmID x 11mmOD x 4mmW Sealed Ball Bearings 4 each Front and Rear Diff Pinions
LOSA6954 5 x 10 x 4 Sealed Ball Bearings (clutch bearings for Ten-T)
LOSA6956 12 x 18 x 4 Sealed Ball Bearings 6each F/R/C Diff outdrives
LOSA6957 10 x 15 x 4 Sealed Ball Bearings Plastic Retainer 4ea Inner Hubs
LOSA6958 6 x 12 x 4 Sealed Ball Bearings with Plastic Retainer 4ea outer Hubs
Factory Parts Listing
http://www.horizonhobby.com/Products/RelatedParts.aspx?ProdID=LOSB0127&Category=Parts%2 0Listing#prodDetailTabs[/URL]
Parts Weight
Losi stock battery tray: 2.8oz/79g
Losi stock rear hubs: 7g
Losi aluminum rear hubs: 10g
Parts Weight
Casey Pecks win at the Nitro Challenge- http://vimeo.com/20541530
SaladFork & SC Rage - http://www.youtube.com/watch?v=3lYe7T0S7To
Blitz sized bodies fit with the least trimming. SC10 bodies fit but require more trimming.
PM me with any TLR SCTe win and I will post you here.
Anyone who has been reading the thread knows the diff pins on the first shipment of trucks have diff pins that are to soft for brushless power. Losi has updated the pins in the second shipment. If you suspect you have the older pins, contact Horizon Hobby (877) 504-0233, they will send you new pins free of charge. We don't need you to post about how pissed you are, we get it... It happened to all of us.
Diff Pins
The diff pins in the truck have been fixed in the seconds shipment of trucks. If you would like aftermarket pins, I suggest using Chrispins ([email protected]) or visit his forsale thread located here - http://www.rcshortcourse.com/forum/s...ad.php?t=18851
Diff pin length
24 mm long 3mm thick and the grove in the middle is 3mm long and 1.5mm deep
Chassis droop screws
Keep an eye on your chassis where your droop screws hit the stops. The small screws will chew down the chassis over time and cause premature wear. You can prevent this by installing 4-40 x 4mm Droop Screws (part#LOSA6253) http://www.horizonhobby.com/Products...rodID=LOSA6253
Servo Saver
From the factory check your servo saver for tightness, we have seen this comes loose and causes steering issues. Red loctite seems to be the fix, blue loctite just doesn’t hold over time.
Diff Pins
Diff pin length
Servo Saver
OEM Hop-up Parts
http://www.horizonhobby.com/Products...prodDetailTabs
Front/Rear Lightened Outdrives Part # LOSB3575
http://www.losi.com/Products/Feature...rodId=LOSB3575
Center Lightened Outdrives Part # LOSB3576
http://www.losi.com/Products/Feature...rodId=LOSB3576
Technical Questions: Questions about this product should be directed to Horizon Hobby's Product Support department.
Horizon Hobby, Inc.
ATTN: Product Support
4105 Fieldstone Road
Champaign, IL 61822
Email: [email protected]
Support Phone: (877) 504-0233
Fax: (217) 355-1552
Horizon Hobby, Inc.
Champaign, IL 61822
Fax: (217) 355-1552
It's about time!
Sure nice to see they went with a roller without electronics.
I'm actually kind of supprised it wasn't realeased under the TLR banner, does look good though!
Looks good. I will like to see some more info about it though. Doesnt look to be what everyone thought it would be as it appears to be a different chassis/layout than the Eight Buggy. The Eight Buggy is bulletproof in my experience so maybe this will be too. Lets just hope its not made by the same guy who designed the Strike (out) .
TLR carries kits and rollers.
I wouldn't count it out just yet...
Super Moderator
Trader Rating: 31 (100%+)
Every Pro driver I can think of is RACING one if their company makes one. They get paid to put their brand on top so I'm pretty sure they're racing when they put them on the track. For some of us die hards 1/10th mod buggy is the ultimate class but with the SCT class bringing such a huge fan base it's VERY important for them to put there truck on top. Probly more so than buggy. SCT is the new win on sunday sell on monday for these companies. IMO anyway.
It should be TLR product for sure. SC's are not really bashers IMO especially with how huge the class is now. Ditch the 'race roller' release it as a kit and slap on some TLR logos. Save the "Losi" brand for RTR's
Looks like another home run for Losi. Just waiting on a TC and a 4wd buggy
