Team Associated TC5
#9212
my car did that when i put lipo in for the first time and never had any weight on to balance it so that may be your answer.
#9213
Just picked up a front one way. Where do the two rubber o-rings go? I am guessing that they go in the outdrive where the dogbone goes, correct?
Thanks.
Under200
Thanks.
Under200
#9215
#9221
I usually add a few drops of ca glue to the slots where the pin rides in the pullies as I assemble the layshaft.
#9222
Here is the latest setup I have been running for 13.5 or 10.5 ! It is the one I used at Snowbirds !
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Bumpsteer : 3mm (silver ballstud )
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
2.5mm for arm mount shim
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
Thick Grease in front diff
A3 belt tension (midlow)
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1mm for arm mount shim front
2.5mm for arm mount shim rear
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
xray 17lbs spring (white)
B15 for belt tention (lowest)
Parma Magenta Tires (new compound)
56.4mm
protoform r9 body
hope you guys like it !!!
Front :
ride height : 4.2
camber :1.5
caster :6
Toe : 1 out
hex spacing .5mm
wheelbase : 1mm
steering link : 2B
Shock position : 2A
Camber link : 3
Arm mounts Both 3A
1.5mm uptravel
black rollbar
60 weight oil
#3 piston
xray 28lbs spring
REAR :
ride height : 4.2
camber :2.5
1 deg Hub
Toe : ~2.75 deg
hex spacing .75mm
wheelbase : 2mm
Shock position : 2B
Camber link : 3A
Arm mounts Both 2A
1.5mm uptravel
black rollbar
30 weight oil
#57 piston
56.4mm
protoform r9 body
#9223
#9224
Ti racing had some that they sold and I got one, it is not much better than the stock one other than being titanium. I do not even use it, the drive train feels freer with the stock one anyway!! I think the slop cmoes from the molds at the factory because I have tried replacing them myself a few times for wear and they do not improve at all. The only way I think you could improve it is too super glue it together or something.
#9225
Anyone have the shock spring kit number?
