Schumacher Corner
#8836
that luck! I finely get my mi2 going and the the only track in houston is closed. what a week end. I put in a 10 d. just to try it out and it hooked up like a rocket out of the hole had alittle slippage and then the rear belt broke! Im glad that happen on a off weekend. My mi2 was hooked up for the few runs I made with the rear hooked tight. now I have to get a belt!
could someone give me the demetions of the two belts and see if I could mach them up with something else I thank I know the rear belt. but didnt want to count the front belt or take it off the car.
#8838
Thanks, Dave. Just lurking about, reading up on the new car. See you at the track.
Good luck at the 'Birds. To quote your oh-so-favorite phrase, "GIT-R-DONE!"
Rob
Rob
#8839
i have the aluminum front nukles, and i was going to use the optional holes but it limmited the stearing one the car. is there a way around this? the servo saver arm was bumping into the stearing ti rod.
#8840
finally
finally got all the oklahoma brahma drivers converted to the Schuie.....use the force guys....
#8841
indoor track
thanks rob, i hope there still racing when i come down there from parkersburg west virginia in a couple of weeks
#8842
hey thanks guys ill try those things on friday
#8843
john_s, pro bearing uses Tungsten Carbide balls, much better
#8844
Shock rebound
I have just rebuilt my TRF shocks (how easy are they to do )
I filled the shocks with oil (35w schuey oil) to the top of the housing so there was no air in the shock, but although the shock feels very smooth I get full rebound from the shaft (shaft extends to it's full extension).
Is that wrong and if so Why?
What will it cause/
Also my front two shocks had a red damper rubber between the top of the bladder and the housing, but the rear did not, should I have put it back and why.
The shocks came on the car when i purchased it second hand, so it's the first time I have had them apart, so i'm not sure what normal should be.
Mick
What will it cause/
Mick
#8845
Ratter, re-bound can be adjusted depending on where the shaft is when you put the top bladder on. If you want less re-bound, push the shaft into the body a little before putting the bladder on and bleeding the excess oil out.
The pink foam increases rebound. Personally i don't use it in any of them.
