Xray X1 - Formula One Car >
Like Tree305Likes
Old 01-06-2015, 06:39 AM
  #376
JoJo1241's Avatar
Originally Posted by cmy55s
Hey all. Is anyone using a 48p spur gear in their car? I use kimborough Spurs in my old top rebel but no longer have the car or the Spurs to see if they fit the X1. Not a fan of the 64p. Thanks
Pat
the kimbrough will fit, no problem.
I have one in my X1 at this moment.
JoJo1241 is offline
Old 01-06-2015, 07:37 AM
  #377
cmy55s's Avatar
Cheers mate.
cmy55s is offline
Old 01-06-2015, 02:38 PM
  #378
JoJo1241's Avatar
For the ride height on foam on the back,you can drive them off until 54 mm.
Your ride height will be 3,5 mm.
On the front you can not go smaller then 61 mm.
Ride height will be 3,5 mm.
So i think there will be a conversion for the front.
When you can lower the lower suspension arms 4-5 mm. it would be great.
It can be done very simple by using a smaller aluminium mount 376364-O
I was wrong about the front ride height.
I build the front as the manual said, and there are 2mm. shims placed under the aluminium mount.
When you remove them, you can ride your foam tires of untill 57 mm. by ride height 3.5mm.
JoJo1241 is offline
Old 01-06-2015, 03:42 PM
  #379
xrayracer1's Avatar
Originally Posted by Skiddins
Put the springs on as per the manual, then mount that plastic piece which now has the springs on onto your servo.
You can now put the outer section of the servo saver on by pushing and twisting (the servo needs to be at the end of it's travel in one direction so that it's held still), once the saver is almost on on that side, twist the servo around (while still pushing on the out part) so that the servo goes to the end of it's travel in the other direction, this should now push the springs apart so the outer section can push fully home.
Does that make any sense?
Yeah i think i get it.
xrayracer1 is offline
Old 01-06-2015, 05:30 PM
  #380
Evo 13's Avatar
Whats the performance difference between 64 and 48 pitch?
Evo 13 is offline
Old 01-06-2015, 05:33 PM
  #381
xrayracer1's Avatar
64p is smoother and also allows for finer tuning of the gear ratios. 48p is more durable.
Old 01-06-2015, 07:16 PM
  #382
Trader Rating: 22 (100%+)
Those of you that have run the car, have you tried the battery both directions? I know my crc car it runs lengthwise, but this car allows it to go lengthwise, and transverse.
If you have tried it both ways, which did you prefer and why?
Im thinking about setting mine up with the ESC standing up on one side, so I can switch it around at the track. Just wanted some feedback if you have tried it
goneracin is offline
Old 01-06-2015, 11:40 PM
  #383
Absolute Hobbyz has them as of now.
sracer811 is offline
Old 01-07-2015, 01:35 AM
  #384
Skiddins's Avatar
Transverse should be better.
Almost everyone in 1/12 runs transverse as well.
Skiddins is offline
Old 01-07-2015, 02:52 AM
  #385
JoJo1241's Avatar
i have not driven mine yet, but 2 friends of me did.
They both have the battery transverse.
The car has massive steer, but was predictable.
So they liked it a lot.
No experience with in line battery yet.
One was on foam and the other on Ride rubber (ETS)
It was on carpet.
JoJo1241 is offline
Old 01-07-2015, 02:54 AM
  #386
xrayracer1's Avatar
What front wing were they using? High or low downforce?
Old 01-07-2015, 04:32 AM
  #387
JoJo1241's Avatar
The one on foam was using the low down force wing.
The other one i do not know.
It was on carpet .
JoJo1241 is offline
Old 01-07-2015, 06:59 AM
  #388
Hey guys and girls....I got an idea! how about everyone post pix of the completed X1.......I get to try mine tonight at practice.....I can't wait, gunna be a long day at work. have a great day everyone.
Shaun B22 is offline
Old 01-07-2015, 07:05 AM
  #389
Evo 13's Avatar
Shuan B22,
Sounds good to me. My kit is complete. just waiting for the body, wheels, and electronics to arrive in the mail.
Hey Guys,
Whats a good lipo to get for this car? You guys running 1s or 2s?
SMC is my first choice but at present, they don't have any 2s shorties in stock. I'm running a LRP x20 4.0t mod motor in mine.
Evo 13 is offline
Old 01-07-2015, 08:44 AM
  #390
Skiddins's Avatar
....I'm running a LRP x20 4.0t mod motor in mine.
Please make sure you video it, will be interesting to see if you have any grip and whether or not it is driveable
Skiddins is offline
