Schumacher Corner
#7021
Re: Carpet Racing in CT
Originally posted by LeadFoot
John Tag:
http://www.hobbychamber.com -- Hobby Chamber, West Haven, CT near the shoreline. There are directions from NY/NJ on the site
If you are looking for a higher level of competition, check out
http://www.rcmadness.com/ R/C Madness in Enfield, CT. They have two factory backed guys that race there. The only issues (unless things have changed) is that the pit area in the winter is cramped and sparse.
I can tell you that Hobby Chambers is clean, well kept with plenty of pit space.
XRAY, HPI, Associated and Yokomo are your main competition at both locations. Anything else and make sure you bring all your own parts.
John Tag:
Leadfoot, I plan on going to there 2 races in october,I also heard there goina put the carpet over the asphalt without plywood,hope not seeing that can really kill carpet with temp changes. I also plan on a trip or to to madness but my weekly track will be dc in PA. they also have some heavy hitters that usally make nat a-mains . See ya at Hobby chamber in oct
#7023
My "snowbirds" setup might be a good starting point http://www.racing-cars.com/usa/searc...e1=prodvalue14 Try this setup as is first, then make changes.
A few things I would try with this setup now that the car has been out a while:
Battery moved all the way in.
Lower, inner hole one rear hub.
#7024
John Tag:
Check out the Forum on the Hobby Chamber website -- you can get in as a vistor. According to what the shop keeper is saying on the forum they are laying down plywood and then putting the carpet on top.
If things have changed, I don't know.
He will have a LOT of problems if he tries to stick the carpet on the asphalt. Last I talked to the shop keeper he said he was going to have it power washed. But, there was soooo much sauce on the track that one of the days I was there you could see it seeping on the track.
I plan on visiting the track this week, will let you know more soon as I check it out
#7026
gary u cant race foams, rubber is still a chalenge for you jk
when u getting foams tires on that mi2 or yours
lazy
lazy
#7028
cool beans, i forgot u had the pro4
#7029
Yup, but no gear problems on the Mi2 though I actually drove the car, box stock, at the Hitec race. I qualified like 6th and finished 7th. I was as high as 3rd and got taken out. I've been really impressed with the car so far. I tried it at Trackside with a Brushless motor and it was decent on 27's, but it needed a little more. I think with a one-way or spool it would really come to life.
#7030
Gary, thanks for bringing magazines to the TCS nats. I needed the box they came in badly.
#7031
idk, traction is pretty high at the moment cuz we have ran the same track for about 2 months. so a dual diff are is gunna be faster as of this point,you could try the thickest front sway-bar, and some soft springs(kinds like blue/sliver or gold/silver like the stk hpi pro4,)but i bet its nice not having gear problems anymore
lazy
lazy
#7032
John Tag:
John Tag:
#7033
Lazy, for foam I think I'll want to run a spool anyways. Plus I know I need to get my hands on the Mi2 swaybar set as well.
#7034
Originally posted by RC Driver Gary
what, to put all your bounty that you won in?
#7035
a spool Gary....some body needs to step out of dream land I even know u dont run anything but dual diffs on a foam car or are u not running this on carpet? but yes if u get a spool to work, idk something must be wrong with this picture
lazyboy
