T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 10-07-2011, 04:06 AM
  #8311
Originally Posted by TeamWTF
I love the new look. I love the old look too. Which is faster? According to an Aussie tester... New car is MUCH faster in Mod...
BRING ON THE BEEFIER GEAR DIFF AND PUT IT IN THE BOX!!!
looks like the cat is out of the bag, appears to be a car on display at IIC.
The proto we have been playing with has been very impressive so far, was perfect to build, responds well to changes, and generates much more traction and corner speed in mod than the old car.
I believe from the feedback received there have been some further changes, so only good things ahead.
For those transferring from the Photon, all plastics and drivetrain are common, so all the spares can carry accross.
Toe blocks are the same as the old Scythe, and the Sabre (again less parts needed, and proven pieces)
All good things for TOP over the next year or 2.
Besercoe is offline
Old 10-08-2011, 03:30 PM
  #8312
TeamWTF's Avatar
Trader Rating: 11 (100%+)
Hopefully more pictures to come...
TeamWTF is offline
Old 10-08-2011, 05:53 PM
  #8313
Trader Rating: 14 (100%+)
Anyone has a setup for RCGT class for this chassis?? Also, does the lipo chassis make a big difference in this class?
DuckStang is offline
Old 10-08-2011, 06:07 PM
  #8314
Buckaroo's Avatar
Depends on your surface, but the setup that Hanulec posted is awesome for 17.5 RCGT on soda prepped asphalt. I found that to make it work overall, the HPI pro compound X tires worked best.
As to chassis, what are you starting with? I'm assuming the 6 cell chassis? I ran the Lipo chassis first, then the Exotek chassis. Neither was at a disadvantage to anything else out there.
Buckaroo is offline
Old 10-08-2011, 06:32 PM
  #8315
I will run on carpet.
Old 10-09-2011, 06:25 AM
  #8316
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
does anyone know how many mm are between inner bulkheads?
Marcos.J is offline
Old 10-09-2011, 06:28 AM
  #8317
J SiN's Avatar
24mm give or take
J SiN is offline
Old 10-09-2011, 06:31 AM
  #8318
Super Moderator
Marcos.J's Avatar
Originally Posted by J SiN
24mm give or take
thanks
Marcos.J is offline
Old 10-10-2011, 02:33 AM
  #8319
Photo's of the new Photon are on RED RC
mcb-jet is offline
Old 10-10-2011, 02:45 AM
  #8320
Aweome detailed pics, i have not seen those alloy camber and shock balls before, they would shed a number of grams off the car in all the right places.
Fail on the car build though, look at the positive camber
Besercoe is offline
Old 10-10-2011, 02:56 AM
  #8321
danjoy25's Avatar
Trader Rating: 38 (100%+)
alloy balls will mean more wear, so hope they don't change and whats the go with the front alloy driveshafts, please include steel.
danjoy25 is offline
Old 10-10-2011, 03:06 AM
  #8322
The alloy balls wear very well,I have them on our cars.I hope they supply xray Ecs instead of those alloy shafts
mcb-jet is offline
Old 10-10-2011, 03:07 AM
  #8323
I really like the car in every direction except for one: why those inner hingpin clamps? I loved the ''old'' system for it's easy and fast adjustment and had never problems with incorrect settings between left/right. Ok this will lower COG but if you want to adjust you have to buy new clamps and I think it will be a struggle to get the clamp in. All other parts are looking perfect though.
koney is offline
Old 10-10-2011, 03:15 AM
  #8324
I don't like them either,but I guess we are stuck with them
mcb-jet is offline
Old 10-10-2011, 03:22 AM
  #8325
I'll be gettng rid of the sway bar mount,diff and screws when I build this car
mcb-jet is offline
