Team Losi JRXS Type-R
#8641
Most people seem modify it to accept a turnbuckle. I'm not sure why Losi didn't provide a easier solution. Here is one option:
http://www.rctech.net/forum/3510891-post4989.html
#8642
RedRocket
#8643
USVTA gearing for Type R
Hi All,
What's the magic gearing combo for a LiPO / 21.5 / JRXS 1.83 tranny for USVTA (assuming track is large enough that you want the max 4.2 FDR)?
I started to work the math...... I saw a 115 spur & 44 pinion would be almost dead nuts on, then realized that nobody makes a 115 spur (I don't think)
So, I'm opting to see if anybody already went through this???
markf3x
markf3x
#8644
Hi All,
markf3x
markf3x
#8645
Go with the 118 spur, its just easier
#8646
#8647
Mike, on your carpet foam setup are you using standard or offset rear hubs? Thanks!
#8649
Will pay. Top dollar for new or used type r oneway
#8650
lunsford turnbuckles: 1061
standard losi kit ball cups: losa6017
Shortneck camber link ball stud: losa1233
or
tallneck camber link ball stud: losa6026
Also just in case.
standard losi kit turnbuckles: losa6532
#8653
Joel covered most of the stuffs there...
For the ballstuds you will see the lenght of the shaft between the shoulder and the ball is different by .030
#8655
Just curious, but has anybody noticed how unmatched the c hubs are? I had to go through 3 packs of 6 degree blocks to find two that were even close to being drilled the same.
