Losi 8ight building and setup >
Old 02-03-2008, 12:44 PM
  #6106
xlgraphicspro's Avatar
I just got a up close and personal look at the new losi chassis, and I'll say maybe you should hold off on spending 100 bucks. I'm not saying the chassis doesn't work, but the only difference it the edges are milled down 3 seperate slots on either side of the chassis. and the flywheel opening is beveled a bit more. The actual milling is pretty rough looking, and any machine shop can do the same thing to a stock chassis for 10 bucks. atleast that's what I'm gonna do. I don't usually knock losi products like this, but charging that much for what they did is outrageous!
xlgraphicspro is offline
Old 02-03-2008, 12:46 PM
  #6107
Someone please prove me wrong and point out something more substantial about this chassis to justify buying a new one instead of machining it myself.
Old 02-03-2008, 12:59 PM
  #6108
SteveJa's Avatar
Trader Rating: 17 (100%+)
Originally Posted by losiboy
where did the part come from
http://www.mcmaster.com/
SteveJa is offline
Old 02-03-2008, 01:01 PM
  #6109
ezveedub's Avatar
Not too many people have the equipment to mill out a chassis. Also, are you just going to mill a stock one out and say its the same thing? I would make sure its the same material, as this one could be a different metal, so it may twist or flex differently. Remember, $100 is the going price for this chassis. Most other brands are the same or more on retail, but have been out longer, so they are found for less money now.
ezveedub is offline
Old 02-03-2008, 01:07 PM
  #6110
pink_sleeve's Avatar
Trader Rating: 221 (100%+)
losipartshouse.com has them for $79.99
pink_sleeve is offline
Old 02-03-2008, 02:08 PM
  #6111
asuming it might be made of a different grade of aluminum? I'm hoping some one has some insight on why I shouldn't just do it myself. I was also dissappointed on the quality, not very losi like.
Old 02-03-2008, 07:53 PM
  #6112
Nik
Nik's Avatar
Its just the old chassis with the sides milled out a bit. Just a running change is all. Im going to say it will probably be included in the new kit. If I ever need a new chassis i'll get this one, but its not something I NEED.
xlgraphicspro, id just mill the old one. Shouldn't be that difficult
Nik is offline
Old 02-03-2008, 07:55 PM
  #6113
tex1's Avatar
Smile
I'm sure anyone could copy it and you could just cut out your own if you wanted. The material in the current chassis is 7075. It is a very dense aluminum. I do not see why they would change that. It would not make sense at all.
I run my car stiff anyways. Don't really need something that will flex more.
TEX
tex1 is offline
Old 02-03-2008, 07:58 PM
  #6114
Nik
Nik's Avatar
actually now that I look at it, it looks like its been milled out even more. The low spots look lower then the old chassis. (or it just looks that way since the anodizing is darker)
Amain has the new one for $99 and the old one for $90
Nik is offline
Old 02-03-2008, 08:08 PM
  #6115
ezveedub's Avatar
The trend now is a flexing chassis that allows more grip and stability. Too stiff, and the car get twitchy. Depends on your driving style. The RC8's chassis flexes, that what gives it the stability and grip it has.
ezveedub is offline
Old 02-03-2008, 08:13 PM
  #6116
When Honda came out with the aluminum framed cr250 it was too stiff. They have since then engineered more flex into it.
indaway is offline
Old 02-03-2008, 09:43 PM
  #6117
ezveedub's Avatar
The flex though has to be engineered correctly. As you read about the new chassis, you'll see that they mention it allows flex without flexing at the gear mesh. Thats very important, so if you do just mill a stock chassis, make sure what you do doesn't ruin it. I assume the new chassis is a different material, because if its too stiff, it will be tweaked when flexed to much. It looks more like the chassis will twist more than flex fore and aft.
ezveedub is offline
Old 02-04-2008, 12:59 AM
  #6118
johnkemp's Avatar
hi i was wondering were and how you have mounted your transponders on you eight pics to please thanks
johnkemp is offline
Old 02-04-2008, 01:14 AM
  #6119
RETRO RC's Avatar
Originally Posted by Teufel Racing
I'm sure its probably in here somewhere, but for the heck of it I'll ask anyway. Has anyone found something better for the stock rubber shock boots? I seem to get holes in them pretty quick and think the if there is a leaky seal in the shock that boot will act like a vacum, pulling out more oil with each stroke. I may have found something that will work until I find a better mouse trap. What I have done is use the stock Jammin orange dust covers that go on the bottom of the shock with the felt inside and work them over the 8ight shock bottom. It is a tight fit and takes some effort to get them seated down as far as they can go. It doesn't seem to bind up the shaft any and have held up so far (about half of last season). I haven't seen the new Jammin shocks, but if that go with something that close to the orange dust boot that had on the smaller shocks, just bigger it could be easier to adapt them to the 8ight shocks.
lose the felt you dont need it as the boots are designed for a 3 mm shalf and the losi shalfs are 4mm I've been using them for almost a year now and they work perfectly without the felt
Adrian
RETRO RC is offline
Old 02-04-2008, 01:19 AM
  #6120
Trader Rating: 42 (100%+)
ridgewaybodies is offline
