Setup for drift
Hey Guys,
I am looking for a setup for high speed drifting.(Corally Assasin) Using a 60a xerun xtreme stock with a Xerun 17.5t motor.
Also what would be the best software?
Tires on car are HPI Type A Super drift.
Just ordered a LRP X20 8.5T for new setup.
Thanks,
Quito
Thanks,
Quito
sameone cna help me to find a good setup?
my car is a hot bodies tcx, motor is a lipotech xr 10.5T and the esc is the 120A V 2.1
Hello guys! I have a hobbywing V2.1. I use this speedo since 2011 and i had not any problem since yesterday race... when i give full throtle on the track's straight the car gets in brakes. if i push the trigger veeery smoothly the car accelerates. Has anyone any idea what is going on? Thanks in advance
Hi, slightly off topic but thought this would be the best place to ask. I need a sensor board for a xerun 13.5t motor. Does anyone know where or if its possible to get one. Preferably in the UK. Thanks :-)
Glad to be able to help
i run the hobbywing v3 with a gm2012 13.5t at the aldershot uk track
this is my setup if it helps
General settings
profile 6
running mode forward/brake
voltage cutoff disabled
esc over heat protection 125deg c
motor over heat protection 125deg c
throttle control
puch rate switch point 50%
1st stage punch 30
2nd stage punch 30
th input curve linear
brake control
drag brake 0%
brake strength 87.5%
initial brake = drage brake
brake rate switch point
1st stage brake rate 20
2nd stage brake rate 20
brake input curve linear
Boost
boost timing 42deg
boost start rmp 1500
boost end rpm 17500
boost slope linear
boost controlled by th yes
turbo
turbo timing 22
turbo activation method full th
turbo th delay 0.2s
turbo start rpm 19000
turbo engage slope 24deg/0.1s
turbo disengage slope 18deg/0.1s
if u have less infield and lots of big straights try adjusting up to 10deg of timing off the boost to the turbo
the esc runs about 46 deg c (with fan)
motor coming off 68-74deg c
the weather temp was around 20deg c
fdr 6.25-6.40
let me know if its good or if anyone else has a good 13.5t setup for a v3
General settings
profile 6
throttle control
1st stage punch 30
2nd stage punch 30
brake control
drag brake 0%
Boost
boost timing 42deg
boost end rpm 17500
boost slope linear
turbo
turbo timing 22
turbo th delay 0.2s
fdr 6.25-6.40
I am putting together a new 12th scale and would like to try a hobbywing esc. will be running 17.5 blinky and possibly mod at a later date. What esc would you reccomend ? 60 amp ? i do not want to run an extra receiver battery or a booster. Also do i need a program box ?
Yes to the program box.
is there any website were v3 settings are collected?
