Like Tree387Likes
JConcepts Thread
Old 06-17-2014, 08:10 PM
  #7651
KalEl63's Avatar
Trader Rating: 13 (100%+)
Originally Posted by PW
They haven't changed and a SCT will fit.
Thanks Paul for the reply
KalEl63 is offline
Old 06-17-2014, 09:27 PM
  #7652
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
I'm sure Bar Codes will have red. I've actually seen the Webs wear better than Codes; the Webs seem to wear more evenly allowing you to get more runs out of them.
while i wasn't there, at a big race our track had a few months ago, a driver (i think sponsored by jconcepts) ran red dirt webs on our abrasive sugared track and while his ride was hooked up, his tires wore much faster than the guys running X2 suburbs which is why i'm interested in red barcodes.
RC*PHREAK is offline
Old 06-18-2014, 12:58 PM
  #7653
Default front axles for the b5
If you already have the clamping front axles can you just install your titanium axles or do I need your hexes also?
troyd is offline
Old 06-18-2014, 01:47 PM
  #7654
PW
PW's Avatar
Yes, you can install the new axles using the AE clamping hexes .
PW is offline
Old 06-26-2014, 06:58 AM
  #7655
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I am thinking about picking up the JC CF tlr22 front tower. I am trying to greatly reduce my kids breaking, as the stock tower is only lasting 2 weekends. Should i seal the edges on the top?
Wildcat1971 is offline
Old 06-26-2014, 08:10 AM
  #7656
PW
PW's Avatar
Sealing the graphite is a good idea, but don't seal it straight from the glue bottle. Use a Q-tip or old exacto blade to spread the glue along the edge. Sealing straight from the glue bottle allows to much glue into the fibers and can make the graphite brittle.
PW is offline
Old 06-26-2014, 09:45 AM
  #7657
xrayrc's Avatar
Trader Rating: 63 (100%+)
2wd buggy dirt tech inserts
PW would you recommend punching holes or trimming
Inside webbing to soften them
And help them break-in?
xrayrc is offline
Old 06-26-2014, 10:22 AM
  #7658
Jake S's Avatar
Trader Rating: 67 (93%+)
fronts are really good right out of the package. the rears are pretty good too, but i would trim the inside webbing by about 1mm on the rears after running completely unmodded foams. seem to be holding up very well too.
Jake S is offline
Old 06-26-2014, 10:26 AM
  #7659
PW
PW's Avatar
Guess it all depends on the track and traction levels. I like to trim the inner webbing for most of the tracks I run on. I have good luck with mine breaking-in by the end of one club day of racing (2-3 packs).
PW is offline
Old 06-27-2014, 01:12 AM
  #7660
Alqwad's Avatar
Trader Rating: 15 (100%+)
PW-
The Silencer body for the 22 2.0 is really starting to grow on me but I run a rear motor setup. Will y'all be coming out with a Silencer for the rear motor 22? If not, can the MM one be made to fit? Any pics or experience that you're aware of? Thanks!!
Alqwad is offline
Old 06-27-2014, 03:13 AM
  #7661
Tom-sct's Avatar
Default Compound
Hey guys.
I run on a indoor dusty clay track.
I usually use super soft Dirt Webs.
When would I use the indoor clay compound ?
I am always searching for traction.
wouldn't the super softs provide more traction than the harder clay compound tyres ?
Thanks.
Tom
Tom-sct is offline
Old 06-27-2014, 06:13 AM
  #7662
PW
PW's Avatar
Originally Posted by Alqwad
PW-
I actually saw someone this Weds with one and it looked really good. I didn't get any pics, but it fit really nice. I will try and get pics next time.
Hey guys.
Normally golds are used on cool/cold damp clay surfaces with low or no dust.
PW is offline
Old 06-27-2014, 08:04 AM
  #7663
Any chance of making those battery hold down screws that would replace the thumbwheels on the b5 that were on the b4.2. I liked using the wrench better than my thumbs to tighten them
Bubonic-X is offline
Old 06-27-2014, 08:11 AM
  #7664
PW
PW's Avatar
Yes
I've seen a few guys replace the 3mm grub-screw with a 4/40 screw and just use the B4 ones
PW is offline
Old 06-27-2014, 09:47 AM
  #7665
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
Yes, but it would be nice to have the bigger diameter like the b5! Much easier to tighten and loosen!
Yes
BIGSKI15 is offline
