BMI's DB12R
Old 11-15-2007, 03:05 AM
  #2866
protc3's Avatar
Trader Rating: 13 (100%+)
Originally Posted by BSchorr
Jay, do you have any DB12r sticker sheets made up? I had 2 that came with the kit, but spilt some beer on them Didn't see any in the price list.
Ben
Hey ben,
Yes we do. I will try to get them on the site today
protc3 is offline
Old 11-15-2007, 03:12 AM
  #2867
protc3's Avatar
How come 172mm rear width is so special? is that the minimum spec width at a big race or something? what if you went shorter?
172mm is ideal for alot of track conditions being that the wider you make the car in the rear the more stable it is. As you narrow it up, It will increase rear traction and make it harder for the car to rotate(more edgy in a sense). In most conditions we are finding that the wider the better. 172mm it the limit by roar rules that you can go
protc3 is offline
Old 11-15-2007, 03:16 AM
  #2868
protc3's Avatar
Originally Posted by radio_car_racer
What's the ideal position in the motor pod?
Front, Middle or Back?
Does it affect the handling as much as moving the batteries for & aft?
It doesnt have nearly as much of an effect as battery position being that the pod is mostly stationary with the exception to pod compression in the bumps and the gryo effect created when you get on throttle. It is not something you will have much control over either. It is more of a gearing capability thing.
protc3 is offline
Old 11-15-2007, 03:54 AM
  #2869
Trader Rating: 51 (100%+)
Jason have you tried testing the DB12R with a thicker\stiffer chassis? Like a 2.8mm to 3mm chassis for example. If so, what were your findings?
Apex is offline
Old 11-15-2007, 04:13 AM
  #2870
protc3's Avatar
We did try a thicker 3mm chassis. It did work good on carpet but was not better than the 2.5mm. They both did yield the same lap times unless we ran stock.In stock the car was a little slower with the 3mm chassis. On asphalt the car was slower with the thicker chassis so we decided that the 2.5mm was the overall better chassis.The added weight of the 3mm chassis and components didnt add enough performance. On high bite carpet we have now found that thicker dampening is required so we are testing a new part that stiffens the car in the rear a bit to help with that. Testing has gone well so i can expect to start production early this coming week.
protc3 is offline
Old 11-15-2007, 05:13 AM
  #2871
AdrianM's Avatar
Like Jason said...don't get hung up on the thicker chassis is better idea. The IIC Mod class was won by a car with a 2mm chassis under insane traction conditions this year.
We did a lot of testing on 2, 2.25, 2.5 and 3mm chassis on asphalt and carpet and the 2.5 wasn't just a conpromise for both its was the BEST for both surfaces. This was proven both in laptimes and driver feel.
AdrianM is offline
Old 11-15-2007, 05:14 AM
  #2872
theisgroup's Avatar
As always, put me down for 2.
theisgroup is offline
Old 11-15-2007, 05:17 AM
  #2873
Nova F1 Racer's Avatar
J, any idea when my order will go out? A couple of people are bugging me already for some parts in that order...
Nova F1 Racer is offline
Old 11-15-2007, 05:19 AM
  #2874
radio_car_racer's Avatar
Jason,
are you planning on making some Castor Blocks in alloy?
If so I'd like to see them in BMI satin grey, similar to the IRS ones so you can just undo the 4 screws and change between 5 & 10 degrees without the need to change the castor blocks
IRS items
I will be sending some parts out for anodizing so if you like i can have dave send me an set that is not anodized and put them in with my order
Jason,
did you get the above sorted for me?
radio_car_racer is offline
Old 11-15-2007, 06:48 AM
  #2875
protc3's Avatar
Give keira a call and let us know what you need because the order is waiting on the new brace
protc3 is offline
Old 11-15-2007, 06:49 AM
  #2876
protc3's Avatar
Jason,
I will be sending an order out this coming week. If you need anything sent with it,now is a good time to send it to me
protc3 is offline
Old 11-15-2007, 07:16 AM
  #2877
Thanks for the feedback. Just wondering where to squeak out a couple more tenths.
Apex is offline
Old 11-15-2007, 07:28 AM
  #2878
Scottrik's Avatar
Trader Rating: 261 (100%+)
Practice. Like most of us could use.
Scottrik is offline
Old 11-15-2007, 07:34 AM
  #2879
-showtime-'s Avatar
On high bite carpet we have now found that thicker dampening is required so we are testing a new part that stiffens the car in the rear a bit to help with that. Testing has gone well so i can expect to start production early this coming week. [/QUOTE]
Are you making a cross brace for the rear damper mounts?
-showtime- is offline
Old 11-15-2007, 08:21 AM
  #2880
protc3's Avatar
It is a new set of side wings with a cross brace incorperated into it. The Wings and brace are all one piece. This is going to be an option part for high bite being that the car works best on lower to medium bite and asphalt with the stock side wings. On higher bite where we really need to use the heavy dampening and free up the rear, this new brace accomodates these conditions. The brace will be the same price as the stock wings.
protc3 is offline
