Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-24-2013, 03:40 PM
  #18781
tony gray's Avatar
Originally Posted by redbarton
I just picked up a Carson 914 body for my M05. I need some offset wheels for it. I can't use the HPI MX60 wheels since they don't meet our class rules. Does someone else make 6mm offset wheels in the true Mini size? I can't seem to find any. Thanks in advance for any help!
Ride used to, but they don't list them any more. You'll need to find a shop with some old stock.
tony gray is offline
Old 04-27-2013, 02:30 PM
  #18782
Core Creations's Avatar
Trader Rating: 108 (100%+)
Default Custom Cooper body for sale!!
http://www.rctech.net/forum/r-c-item...l#post12092630
Core Creations is offline
Old 04-28-2013, 11:07 AM
  #18783
typhon92's Avatar
beautiful body!
typhon92 is offline
Old 04-28-2013, 08:06 PM
  #18784
tony gray's Avatar
2013 Australian Mini Nats - Video for all 3 A Finals.
Leg 1 - http://youtu.be/WrwHElHXb_Y
Leg 2 - http://youtu.be/4yEMO9b9o84
Leg 3 - http://youtu.be/Li4RHeZ8jWo
Old 04-29-2013, 12:35 AM
  #18785
marcos graveyar's Avatar
Watching those was the best start to a Monday in a long time
marcos graveyar is offline
Old 04-29-2013, 11:51 AM
  #18786
redbarton's Avatar
Thank you for the info. I found some.
redbarton is offline
Old 04-29-2013, 03:13 PM
  #18787
gruman28's Avatar
Trader Rating: 18 (100%+)
Mini nats Minis look fast! Are they running 13t motors? Speed gears?
gruman28 is offline
Old 04-29-2013, 03:23 PM
  #18788
tony gray's Avatar
13 turn H/Wing combos yes, standard gears.
Old 04-30-2013, 01:24 PM
  #18789
KA2AEV's Avatar
Guys whats the difference between the Standard and the Speed Gears?
Are the Speed Gears TCS Legal?
KA2AEV is offline
Old 04-30-2013, 01:46 PM
  #18790
bizkit1's Avatar
Trader Rating: 27 (100%+)
Not TCS legal at all, and if you are caught with them you will be disqualified
As far as what it gains you, not a lot. It depends more on the driver and his setup of the car.
bizkit1 is offline
Old 04-30-2013, 01:54 PM
  #18791
tony gray's Avatar
Speed-tuned gears are also exceptionally poor quality and very often the numerical gain in gearing is offset by the poor mesh causing extra drag.
Old 04-30-2013, 02:30 PM
  #18792
monkeyracing's Avatar
+1. The commonly available speed gears are generally not terribly round, but they are made of soft cheese, quite likely Boursin or Havarti, should you need a snack.
monkeyracing is offline
Old 04-30-2013, 03:35 PM
  #18793
Morbo's Avatar
Originally Posted by monkeyracing
+1. The commonly available speed gears are generally not terrible round, but they are made of soft cheese, quite likely Boursin or Havarti, should you need a snack.
Morbo is offline
Old 04-30-2013, 06:26 PM
  #18794
KA2AEV's Avatar
Okay all I needed to hear was that It wasn't TCS Legal
That settles it
Now Im off to make a grilled cheese sandwich!
KA2AEV is offline
Old 05-01-2013, 01:06 AM
  #18795
Mmmmmmmm..............cheese.
